Old 08-03-2008, 01:06 PM   #1
FrankHoy
FrankHoy's Avatar
Patch Panel parts source?
Does anyone know who carries these patch panels?:
lower rear cab center (cab corners do not cover this center section)
Rear floor panels (THis would be for the floor section against the back wall. No patch panels I have found cover the center rear of cab floor, only complete floors)
Tailgate lower section cap/replacement patch panel (this looks like a U and replaces the lower 6" to 9" of the tailgate where they typically rust out. I know I have seen these offered before but can not find them at any vendor.)
Thanks for any help.
72 Cheyenne 2wd LWB 402/350 CC/PS/PB/AC Tilt/Tach
(upgrading to 4X4 402/700R4 CC/PS/PB/AC Tilt/Tach PW/PL)
71 Custom Deluxe 350/350 Tilt/PS/PB
00 Blazer
FrankHoy is offline   Reply With Quote
Old 08-04-2008, 04:43 PM   #2
lks dcvn
lks dcvn's Avatar
Re: Patch Panel parts source?
lower rear cab center (cab corners do not cover this center section) - not reproduced - you will need to fab them up or find the metal from a donor cab
Rear floor panels (THis would be for the floor section against the back wall. No patch panels I have found cover the center rear of cab floor, only complete floors) Same deal - I got some patch panels cut out of an AZ truck that was being parted - unless you want to fab them out of steel
Tailgate lower section cap/replacement patch panel (this looks like a U and replaces the lower 6" to 9" of the tailgate where they typically rust out. I know I have seen these offered before but can not find them at any vendor.) I have never seen these - that doesn't mean they don't exist - just have never seen them. May need to fab these up as well
Hopefully someone else will chime in about the last one...good luck.
lks dcvn is offline   Reply With Quote
Old 08-04-2008, 05:00 PM   #3
FrankHoy
FrankHoy's Avatar
Thanks for the comments.
The floor is not as critical, as I could fab that fairly easily, just was hoping someone might offer a patch panel that would have the little hump and pre-drilled seat belt bolt holes, etc. I need a patch strip about 8"-10" wide along the back wall.
Back wall I can patch in if need be but again was hoping to find a panel that would have the indented areas already preformed. My wall mainly has a rust strip line, where the floor welds to the back wall.
Wish I could remember where I saw the tailgate panel. May have been at a swap meet vendor, but I do remember it was a new part and not a cut out from a used tailgate.
00 Blazer
Old 08-04-2008, 07:14 PM   #4
What most body guys do is buy the big piece and cut what they need.Or,cut it from a donor.The tailgate?Bolt another one on and toss yours.
