08-03-2008, 04:07 PM | #1 |
Picture request
Anyone running a set of Coys or TT2's in 20 inch on a truck only mildly lowered ? I am going to put something on the Black truck but I do not want to lower it more than 2.5/4 or maybe 3.5/5 . I will not be C-notching it so I wonder if I should stick with 18's like I had on the tan truck or wouls 20's look OK ? Thanks ,
Frank
Born and proudly residing in a Red State ! |
08-03-2008, 05:04 PM | #2 |
Arrived on a Pale Horse
Re: Picture request
Frank, doesn't matter what you do that truck it'll look sweet. I personally don't care for the look of 20's on vehicles this old, looks great on late model stuff tho. JMHO, to each his own.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
08-03-2008, 07:34 PM | #3 |
OL BLUU
Re: Picture request
The 1st pic was a 5/6.5... I dont think 3.5/5 will be low enough to make it look "right". The 2nd pic is sitting at 6/8. If your doing a mild drop... I would stick with the 18" set up that u were running on the tan one. Its not C-notch... but I did have to trim the bump stops down as well.
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 Last edited by CLASSIC87'; 08-03-2008 at 07:36 PM. |
08-03-2008, 09:22 PM | #4 |
Re: Picture request
I think the 20's will still look fine @ 3.5/5 drop & you won't be buzzing the stock front inner fenderwells constantly. Can't help ya' w/the Coys & mild drop but I'll put up a couple of the Coys on my 74. 20x8.5's w/5.25BS & 255/40's; 20x10's w/5.5BS & 295/40's.
08-03-2008, 09:48 PM | #5 |
gearhead
Re: Picture request
at 6/8 are you having any isues with the front tires rubing the iner finders??
2003 GMC Z71 Daily driver 1982 Chevy 2wd short bed, project, boxerdra@hotmail.com |
08-03-2008, 10:08 PM | #6 |
OL BLUU
Re: Picture request
The inner top side of the tire will when I hit dips at 40mph+... but not bad enough for "me" to raise it back up.
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
08-03-2008, 10:18 PM | #7 | |
Re: Picture request
Going back & focusing on the gaps between your wheel lips vs. fender lips compared to mine, I see more rubber on yours. So mine might be a hair lower?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-03-2008 at 10:21 PM. |
08-03-2008, 10:45 PM | #8 |
Happy to be here
Re: Picture request
Frank, 20's will look just fine. If you don't lower it much, the larger wheel will look even better. Just adjust the gap with the proper tire, and your good to go.
Are you considering the polished, or gray center?
08-03-2008, 11:11 PM | #9 |
Re: Picture request
I agree. With the drop you suggested, some 20x8.5's w/245/45's & 20x10's w/295/45's would add a little more meat. 275/45's would also work out back & are a common OE size which might be cheaper.....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-03-2008 at 11:12 PM. |
08-03-2008, 11:16 PM | #10 | |
OL BLUU
Re: Picture request
08-03-2008, 11:32 PM | #11 |
Spear and magic helmet!
Re: Picture request
I think I'm in the minority here, but Coy's never really look as good to me unless they have a 40 series or lower tire. I think it's the lip design. I know the lip is flat instead of stepped, but the outer portion by where the bead sits seems kind of rolled up almost perpendicular. To me, that would spell 20s instead of 18s if I were going with Coys.
I've never had a set, mind you. That's just opinion and observation.
-- Will |
08-03-2008, 11:48 PM | #12 |
Re: Picture request
I love your truck just drop it 3/5
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
08-04-2008, 07:49 PM | #13 |
gearhead
Re: Picture request
this is what my 82 looks like at 6/8 drop. But im runing a big block with the big block springs and it still sits to low with a 3 coil and 3 inch spindle.So Im going to try a 2 inch coil and work from there. the way it sits in this picture the iner finder was rubing on the tire most of the time. I thought about modifying the finder but i want to see what it would look like raised up an inch first.
the tire sizes are 255/40/20 on 20/8.5 in front and 295/40/20 on 20/10 at the rear
08-04-2008, 08:04 PM | #14 |
Re: Picture request
20/22 255/40/20 front 285/35/22 rear 5/5 drop
08-04-2008, 09:38 PM | #15 |
Re: Picture request
Ken , If it is Coys then I like the grey center . In TT2's I like the full polish . Frank
08-04-2008, 11:20 PM | #16 |
Happy to be here
Re: Picture request
Cool! I like those Coys too...
08-04-2008, 11:40 PM | #17 |
Re: Picture request
Question , would the tire sizes Scotti listed above work on a 20x8 with 4.5 backspace and a 20x10 with 5.5 backspace ? 245/45/20 and 295/45/20 .
Frank
08-05-2008, 12:20 AM | #18 | |
Active Member
Re: Picture request
Know this isn't a truck, but here's my blazer with what was a 4/6 with 20x8 4.5 bs and 20x9.5 5.5 bs running a 245/40/20 and 295/40/20's. beautiful truck....I think anything you do to it will be fine
D.M.C -FF- |
08-05-2008, 12:41 AM | #19 |
Re: Picture request
Crush , Its your wheels that I am asking about . I am trying make up my mind .
Frank
08-05-2008, 12:59 AM | #20 |
Active Member
Re: Picture request
I figured.
Just want to make sure they are what you want.....not in a hurry or need to sell them. Last thing I want is buyers remorse from a board member. If you'd like I can go get a pic of what they look like on my '79 as it sits. It's got about a 6/8 drop on it right now (looks like about a 6/9 drop with all the stuff in the bed...lol).
D.M.C -FF- |
08-05-2008, 08:18 AM | #21 |
Re: Picture request
The pics I am after is a shot of how they sit in the wheelwells . How much clearance to the fender lip ?
Thanks , Frank
09-01-2008, 11:06 PM | #22 |
Re: Picture request
redrat like ur truck. Whered u get the grill?
Its Kool to be a square 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers New Mexico Member --- Member of the Square Body Club--- |
