lowering question
Right now my 68 is lowered with 4 inch blocks. I plan to fix this by using 4 drop coils and getting rid of the blocks.
My question is do I need an adjustable panhard bar or shock relocators with 4inch drop coils? thanks
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Nothing to see here.....
![]() Join Date: Jun 2007
Re: lowering question
for a 4" drop it's not a necessity, but...... you should probably pull the trigger on an adjustable bar. it does make a difference.
go with the ECE Super Trac Bar. great quality and fit.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
you should do both the shocks perform better in a straight upright position you loose alot of thier performance the more they are inclined and it just looks better with an adjustable panhard having your rear centered in the chassis
next question ECE or CPP?
Like a Rock!
If you go with the new shock relocators, let us know how you remove the factory rivets! Some say it's easy and some say it's a P.I.T.A!
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
Dave's not here, man
My vote is for ECE. I have several of their suspension components on my truck, including and adjustable panhard bar and rear springs. Their customer service is also FANTASTIC!!
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
ECE is great and as far as the rivets for the shock mounts... I took my bed off to get them otherwise they would have been a PITA. ECE does have great customer service!
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs http://67-72chevytrucks.com/vboard/s...d.php?t=272458 2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds |
ECE, hands down.
Sophomore Member
![]() Join Date: Jul 2006
i took my bed off and they were still a PITA
1972 Chevrolet Highlander SWB 1972 Custom Deluxe 3/4 2WD 60k miles these trucks don't need vacuum gauges cause they don't suck! two wrongs don't make a right, but three rights do make a left all i want is a little more than i'll ever get it's better to be judged by 12 than to be carried by 6 |
i use cpp. all my suspension components and brake components are from them. i have no complaints. everything is high quality with a perfect ride and fit.
Junior Member
I went with ECE on the Wife's '63. Good stuff and great service. I used a cutoff wheel to remove the rivits. A good sharp air chisle would probobly work also.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
quickest way I have found to remove the rivets is to grind the head off, then drill out with 3 incrementally larger bits.
a pita, but easier that banging the crap out of your hands with a cold chisel
save a few bucks in the long run and get ECE's kit, with bar, shock relocator, and lowered shocks.
I use them because the quality is good and I've actually gotten parts in as little as 2 days (Bakersfield is not that far from Fresno). |
Junior Member
![]() Join Date: Mar 2007
the torch is your friend when doing this kinda work. makes quick work of the rivits.
frontstreetcycle on Instagram |
#15 |
I grinded the head of them off too. Been there done that with the cold chisel/hammer hitting my hand.
#16 |
Old Skool Club
![]() Join Date: Jun 2001
ECE stuff is what's on my truck. They get my vote, too.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#17 |
![]() Join Date: Feb 2001
ECE JMHO
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#18 |
Yes I was think the kit from ece I would like to go with 5 inch kit but then I think my back will be lower then my front my back sits at 30 inches to wheel arches now
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO Last edited by 76bonanza; 08-05-2008 at 01:17 PM. |
#19 |
![]() Join Date: Oct 2007
I dropped mine 3 1/2 front and 5 rear. Used all ECE components. I ground the rivet heads off with a grinder, popped out what was left with a punch. Wasn't too bad. Excellent parts and customer service beyond reproach in my dealings with them. JMO!
Paul
1972 c10 ![]() 2000 FLHTC 126+k miles, so far ![]() 1967 BMW r60 2007 Xterra (Wife's ride) R.I.P. "ESLL" |
#20 |
![]() Join Date: Apr 2008
I remove rivets all the time.I use an air hammer with chisel bit.Takes about 10 seconds apeice.If you dont have an air hammer the cutoff wheel is next.
#21 | |
Always on the hunt...
![]() Join Date: Sep 2006
![]() I would stick with ece, especially if it's gonna be an order/pay by phone and ship deal! ! ! |
#22 |
I used the stock panhard on my 4" drop, but I relocated the shocks.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
#23 |
got mine from ece 4 / 6 like it alot
