08-04-2008, 10:31 PM | #1 |
Old member
Helper air bags for the rear
OK,
I know what your going to say they don't look right and your correct they don't. They don't make a kit for our trucks so I guessed at the kit I needed and then ordered some more rubber bushings also that where thicker. I think I need to shave some of it off to make a better fit. Haven't drove it yet since I just finished it up to this point tonight. I ran 2 seperate lines for them so I want have the pressure swaping from side to side. I ran each line back through the frame rail then used the 2 air valves to mount my tag. First is with caps on: Next with them off:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 08-04-2008 at 11:25 PM. |
