Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-04-2008, 10:42 PM   #1
redhead69
fugedaboutit
redhead69's Avatar
Carnage (a.k.a. Cletus Kasady) thread
Lets see your broken hearts.. I mean parts
So if you break something post it here!!
Heres mine from Sunday
Currently truckless
redhead69 is offline   Reply With Quote
Old 08-05-2008, 12:12 AM   #2
leftcoast66
leftcoast66's Avatar
Re: Carnage (a.k.a. Cletus Kasady) thread
Ouch, that one hurts. Sadly I'm on the other side of the state from my car parts. Got a few though. Got a bmw w/ a bottom end I grenaded. Pretty proud of that. Also when I was 15 rebuilt my muncie m21 and forgot a bearing in the cluster gear oops, and blew up the input shaft and cluster gear. For some reason no matter how hard I am on my truck, never breaks much of anything.
leftcoast66 is offline   Reply With Quote
Old 08-06-2008, 09:12 AM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Redhead,, my guess that is just the tip of the iceburg,, first question I ask myself when I see valvetrain damage is WHY??? and WHAT ELSE broke. When you pop th eintatke off to gather up ther rest of the pushrod pieces, might as well take that head off and see the 'WHY' it happened.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-06-2008, 08:30 PM   #4
redhead69
fugedaboutit
redhead69's Avatar
Thats what scares me!!
Marv love your truck, but that nova is too cool!.. I too have a 64 sedan but its got a 250 l6 and is my little cruiser
Currently truckless
Old 08-06-2008, 11:02 PM   #5
shortbed70
shortbed70's Avatar
I used to have pics of my 4.56 eaton brute force carrier that the cross pin bolt backed out hit the housing then wedged between the ring and pinion at 65 mph and BOOM lost the carrier both spiders were split in 2 and the clutch plates and springs were mangled. Whole rear JUNK! Can't find my pics.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-16-2008, 06:42 PM   #6
Ford Assassin
Ford Assassin's Avatar
Updates?
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 08-19-2008, 08:38 PM   #7
85sqbdy
85sqbdy's Avatar
had a friend build one of them stroker 391 smallblocks. good for streetrod or just to say, hey it's a 396 smallblock. but for all out drag racing, not good. here why, as the rev's approached 7000 rpm, it was to late, the rod bolts in the number one and three pistons failed. one can only guess what went next, the crank or the block. from what was left its hard to tell. the pistons were turned 90 degrees in there bores, (have you ever seen an h-beam rod cork screwed), the dart block was cracked from top to bottom, both cyllinders had holes in them from the wrist pins going through. the big solid roller cam was the only thing that survived the short block disaster. went back to the drawing board and built a 421 small block, using the same solid roller cam, he's been running it for three years now with no problems. last pass it made at the track was 8.49 at 158 mph. unfortunately i never took pictures of the carnage, but he came away with the knowledge that rev limiters are a wise investment, and, if it looks to good to be true it probably is.
85sqbdy is offline   Reply With Quote
