I'm swapping my NP203 for an NP 205. I just had new drive shafts made and I want to know if they are going to work with the new t-case. The u-joint size is the same. I'm sure the front drive shaft will be ok, it is longer and has alot of slip. Its the rear I'm conserned about. How much shorter is the NP205 from the NP203? Thanks.
I need all the help I can get. |
I need another Barley Pop
Dale, I show the 205 being about 8.5" shorter than the 203. The length of the 203 is 21.5" and the 205 is 13". Here is a link on the dimensions for both cases.
http://www.jeepland.net/tcase.shtml
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
Thats just the link I was looking for, thank you . It looks like I will have to have my d-shaft lengthened. From 18 inches to 26 inches, this should help out alot with my drive shaft angle, and mabe get rid of that vibration. Thanks again.
No problem at all, glad to help if I can.
