Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 08-06-2008, 05:57 PM   #1
mekdad
mekdad's Avatar
blower control problems
1996 s10 blazer my a/c and heat only blows through the defrost and floor at the same time does not even try to blow Through one or the other separately and not Through the dash at all.Any ideas what would cause this? I have replaced the control switch with a used one and no change.
you never know what you can do until you have to undo something you have done!
mekdad is offline   Reply With Quote
Old 08-06-2008, 06:59 PM   #2
54 jimmy
54 jimmy's Avatar
Re: blower control problems
could be a vacume actuator on the heater box behind the dash or a vacume line is pinched mabye even fallen off.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 08-08-2008, 05:29 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Check the vacuum hose behind the air intake over the throttle body. The hose connects to a vacuum resevior to move vents. I had the same problem. I replaced hose because it would fall off occasionally.
Old 08-12-2008, 10:00 AM   #4
mekdad
mekdad's Avatar
thanks for the replys.I checked all of the lines I could get to and all seems fine.Is there a good way to get to the actuator on top of the heater box?I think thats my problem.
Old 08-17-2008, 08:51 PM   #5
gchemist
gchemist's Avatar
You can pull the bezel and check behind the switch for vaccuum.
Old 08-19-2008, 08:05 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
it sounds like you have a problem with the lower mode door or the actuator. it has a brown and a black hose. it is a dual action diaphram.
wait a minute, you said you catn switch from defrost to vent either? the vaccum flows from the manifold (drivers side) to the ball thing mounted to the hood. then to the dash. start tracing the hose under hood using the emissions sticker as a guide.
68C15 is offline   Reply With Quote
Old 08-19-2008, 08:48 AM   #7
mekdad
mekdad's Avatar
I have vac to the switch and it is stuck on defrost and floor at the same time.
Old 08-20-2008, 09:05 PM   #8
Slammed70
Slammed70's Avatar
Dont feel bad, when my fan control is set on the "two" setting my truck clicks.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
