![]() Join Date: Jan 2001
Voltage Regulator - Is this normal?
My battery went dead, and when I hook up the jumper cables I noticed the voltage regulator clicks. It seems to me that if that's the sound of a solenoid closing, the voltage regulator would be drawing battery power all of the time.
So how do I test the voltage regulator? I haven't had to test one in many years. If it's a bad regulator, I'll probably just install the internal regulator alternator I have in my garage. Thanks |
Active Member
![]() Join Date: Jul 2007
Re: Voltage Regulator - Is this normal?
It's a mechanical regulator. They have relays inside that open and close depending on the charging needs of the battery. If you supect it's bad, the new ones are fairly cheap and most are solid state. I converted mine to solid state some time back and it works fine.
http://upload.wikimedia.org/wikipedi...Stabilizer.JPG |
#3 | |
Restoration Virgin!
Use this thread from FAQ to wire up that internal regulated alt.....and trash that external one....it'll cost you nothing!!!!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
its all about the +6 inches
it'll cost nothing after buying a new alt with an internal regulator.
Never Ending Projects
I was running into this as well. Found out the PO had plugged the connector into the regulator in backwards. After plugging it in the correct way, all the problems went away.
It answered the question as to why they had a "kill switch" which would kill all the power to the whole truck. This would keep it from killing the battery. Check the connector and make sure it is correct. I had to search online to find a wiring diagram which I used to figure this out.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... Last edited by chevy_mike; 08-07-2008 at 12:35 PM. |
#6 | ||
Restoration Virgin!
![]() k, I'm busted. |
The only difference with the external and the internal regulator alternators is where the regulator is. Except!..................the externaly regulated alternators have transistors that are beefier and cooled in the case of the alternator.
The rebuilders told me when i asked if |i should go internal one wire and they just laughed " Only if you want to be techy!" The externaly regulated is bullet proof. If ya have one just fix it. The one wire is also a misconception...............the only good thing about them is there is only one wire to hook up...............it stops there! Read the articles on mad electric web site.
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Active Member
![]() Join Date: Sep 2005
cost me 32 buxs to convert over to a internal reg External to Internal Voltage reg. i went though3 after market extrnal reg.s and an alt with no luck then switched tot the internal reg no problems since
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 08-07-2008 at 10:09 PM. |
#11 | |
these things were built solid.
CAN'T FIX NOTHIN
when I was younger I had some car's and truck's with the newer internal regulator type alternator and the HEI distributor's and those were the only thing's that EVER caused me to have to sit beside the road broke down ,
the factory 1960's early 70's alternator and regulator system should be right up there with the best creation's in the automotive world , I have NEVER had one minute's trouble out of one , and they will charge with a piece of string for a belt , the internal one's have to have the belt torqed to 500 foot pound's and then the still sqeal !! 2ND the GM point's type distributor is a mechanical marvel !! bullet proof easy to work on and CHEAP my 67 camaro has had two set's of point's in the last ten year's and that second set is still in the box in the trunk for whenever I need them ,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC Last edited by 19673ontree; 08-08-2008 at 04:37 PM. |
#13 | |
"One Wire" and "Internally Regulated" are not the same thing. A "One Wire" is internally regulated...but it is a newer "Hot Rod" thing. An "Internally Regulated" alternator actually runs from 3 wires. These are the "common" units that are installed from the factory. They are what they used to replace/update the older externally regulated units. |
Active Member
I'm sure cost was one of the reasons Detroit went with internal regulator alternators and mechanical points. Throw in a diode assembly plus some transistors and do away with a lot of mechanical components.
Other reasons could have been the higher power demands of the newer automobiles. |
#15 | |
www.madelectrical.com/electrical-tech check out the articles on the mad electrical web site
#16 |
I had a chrome 1 wire alt built for me at a local Auto Electric shop. Cost $130 and looks/functions great
71 C-10 98 Mustang GT 06 Mustang GT Last edited by stanglifemike; 08-08-2008 at 11:41 PM. |
#17 | |
Gone to greener pastures
![]() Join Date: May 2007
Personally, I'd ditch that glass fuel filter before you burn your truck to the ground & ruin your whole day. They look nice & all, but all you have to do is have it break and pump gasoline all over your hot engine, especially if you're driving. Just my .02.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#18 |
If you go to Madelectrical.com and read the articles you will understand why I am trying to point out that the one wire set up is not the way to go unless it is on a tractor that doesn't have lights or accessorys or a drag car.
with the 1 wire set up the aternator only puts out a set voltage and will not "scence" that there is a voltage drop downstream at the headlights for instace, and it will not "know" to step up the voltage. Don't take my word for it and this is not based on my general "opinion" either, just read the articles and you will undestand what i am saying.
