Old 08-11-2008, 11:22 AM   #1
orange66fleet
Lowered in Cleveland
removing trailing arm bushings
Can someone shed some light on how to remove the old bushing out of the trailing arms. Thanks in advanced.
orange66fleet is offline   Reply With Quote
Old 11-19-2008, 03:13 PM   #2
kcjones
I wish I was a cowboy
kcjones's Avatar
Re: removing trailing arm bushings
Not sure if you got your question answered, if not:
Link
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 11-19-2008, 04:11 PM   #3
ChopperDr
If reusing the metal shells to run poly bushings, use a torch. Let them burn a little, then dig out the crusty rubber bits. If you are replacing with stock replacements drive them out with a press, then press in the new ones.
Chop
ChopperDr is offline   Reply With Quote
Old 11-19-2008, 04:54 PM   #4
scotts62
One day...
scotts62's Avatar
Torch, socket to fit the steel sleeve and a bfh thats how we got a buddy of mines out, i dont think we used steel sleeve over though.
Scott
93 crew cab build
Project 62
Old 11-19-2008, 05:30 PM   #5
kizer
Its Deja Vu time again
kizer's Avatar
When I replaced my ends near the axle. I took a drill with a really small bit and drilled around the inner sleeve 5 or 6 places almost like a star. Then after the holes where in I took a small torch and heated up the rubber some and hit the sleeve with a socket and a hammer and it came right out. There wasn't any rubber to clean out since I didn't rely on the torch.
Why drill I thought well maybe the flame can cook through the holes and it seemed to work pretty well.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 11-21-2008, 09:53 PM   #6
orange66fleet
I did get them removed, I burned the bushing out, then I used a sawza and cut through the metal outer shell, then I pounded it till it was out. The new ones were in seconds flat. Thanks for all the help.
