Old 08-11-2008, 08:05 PM   #1
Ackattack
Ackattack's Avatar
Ordered Old Air A/C system.
After reading on here about peoples 's problems with vintage air systems fogging up their windows, I started looking into Old Air systems.
So today I called them up to see if they could get me a custom setup since I already have a compressor on the front of my 5.3L. I also have the condensor.
So after talking to the sales guy and going through what all I'd need, I just went ahead and ordered it. I got a custom bulkhead fitting that I will probably hide on my shaved firewall. I'm gonna have to come up with a custom mount setup for the under the dash setup, and probably have to order some hard lines once i have it installed. I will probably also have to get a few fittings to connect my newer style compressor with the rest of the system. The guy I talked to on the phone was pretty helpful.
I got the setup to install the factory dash outlets too (mine is a non a/c cab) and I'll also be using the factory style A/C controls....though the guy told me it won't operate exactly like factory....no biggie to me.
I called them up initially just to see if they could do a custom setup, but ended up just ordering it before I got any of your inputs.
So, how do people like thier Old Air setups? Oh, this is the "Hurricane" setup if that matters.
Ackattack is offline   Reply With Quote
Old 08-11-2008, 08:10 PM   #2
big_al_71
big_al_71's Avatar
Re: Ordered Old Air A/C system.
We installed the kit from classic auto air on my friends 72 pro touring camaro and it works perfect, so I ordered a kit for my 71 c10 I have not installed it yet as we are doing a motor swap once the new motor is in I will install it and post picts...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-12-2008, 08:19 AM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Had my vintage kit installed for over a year and drive my truck year round (gotta love the south ) and this is the first I've heard of this "problem."
A/C rocks. Let us know how the install goes.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-12-2008, 02:35 PM   #4
67shortie
Green club
67shortie's Avatar
Congrats on the purchase, I would so love to install one in my truck
On a side note, that Camaro is wicked
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 08-12-2008, 04:47 PM   #5
ERASER5
ERASER5's Avatar
The fogging issue is a heat mode problem, not an AC problem and it is also a more northern problem. Factory HVAC systems always pull fresh air in heat mode. Using heating and recirculation mode (*some cars can) usually ends up fogging your windshield. Most of the after market full HVAC systems use only recirculated air, no fresh air. There has also been the occasional complaint about not enough heat. The complaints are few and far between because only a few of us will put piles of money in our trucks and then drive them in the salt belt states in 0° weather.
Not going to drive in your ride in the winter? No problem.
* Dodge Neons on some years had a separate fresh air/recirculate switch. The manual tell you to NEVER run the heater in recirculate mode or you windows will fog. And it did. Not long after I started working in a Ford HVAC lab, we had a class on Auto type HVAC systems. The same statement was printed in Ford HVAC training manual.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-12-2008, 05:00 PM   #6
Tom G
Product ID: AC0944
Peanut style compressor Block
GM / Sanden V7 OEM compressor Discharge Pad - Allows you to adapt to standard #8 female oring fitting Order as AC0944
Price: $9.98
Product ID: AC0945
GM / Sanden V7 OEM compressor Suction Pad - Allows you to adapt to standard #10 female oring fitting Order as AC0945
Price: $14.98
These are the two adapter fittings if your hose"s mount on the top of the compressor. these i ordered from docs-blocks
Tom G is offline   Reply With Quote
