08-13-2008, 02:38 PM | #1 |
Filling Rockers to prevent rust
So we replaced the rockers on two vehicles. What are you doing to help prevent them from rusting?
08-13-2008, 02:42 PM | #2 |
Re: Filling Rockers to prevent rust
Took a garden sprayer and soaked the inside with POR 15, . I'm not sure what else you can do.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-13-2008, 02:48 PM | #3 | |
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
08-13-2008, 03:36 PM | #4 |
Active Member
I did mine about 15 years ago and painted the inside with rustoleum. Haven't had any problems. But, then again I'm not in rust belt.
I suppose POR15 or similar would help keep the rust down. I have a friend that fillled a cavity in one of his Mustangs that he was restoring with spray foam? I never asked him if he's had any rust problems. |
08-13-2008, 03:38 PM | #5 |
Bad idea, holds moisture/blocks drainage/won't allow water to get out.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
08-13-2008, 04:12 PM | #6 |
Active Member
That's what I thought.
08-13-2008, 04:25 PM | #7 |
Don't drive it in the salt, or allow trash to get in there. That will go further than anything.
It's not the most durable stuff, but you can spray the inside with weld-through primer before installing and still have no trouble welding. They vary in quality, but I think U-Pol makes a good one. |
08-13-2008, 04:26 PM | #8 |
Built 4 Speed
Mine rusted off havent had a problem with them since!
But yes por 15/rubberized undercoating/spray paint. are all good choices. in that order.
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" |
08-13-2008, 04:50 PM | #9 |
I always thought it would be a good idea to replace the outer rocker and leave the inside piece off so that there was nothing there to hold dirt etc. I really don't see the point in that piece.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc. My new build thread: http://67-72chevytrucks.com/vboard/s...17#post2861817 Best pass with the old dragtruck: 5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003 Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup 5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004 |
08-13-2008, 05:06 PM | #10 |
That's what the two cab supports bolt to, and being perpendicular to the floor of the truck, it has a lot of structural strength
08-13-2008, 05:13 PM | #11 |
Official Site Guitar Shredder
I disagree..tom....That (piece) inner rocker basically makes the Outer rocker strong and is a significant part of the cabs structure for the floor supports and just more strength....If it was not ..it would not be there........The best thing i can say to use is........BODY WAX..(also slang for Bees Wax)......you can get it at almost ANY automotive paint and supply company.....Its a wax that not only repels moisture. but does not let the moisture penetrate the metal.....It comes with a wand that has holes in it to give you a 360 spraying surface... also it can reach areas that most others wont because of the sheer small size of the tube......3m makes a good body wax as does Wurth or Kent........................
08-13-2008, 08:43 PM | #12 | |
Rolled on Paint Club
http://www.grainger.com/Grainger/items/4KK25 I may first do a trial on my dailydriver Chevy Tracker. Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
08-13-2008, 08:55 PM | #13 |
Yes some company's do use a type of foam but it will breath and they use it in the vertical areas not the bottom flat portion of the car. I like Por 15 and Body Way for a prevention but I also pre coat the parts with a good rust paint before they go together. The other important part is to make sure the drain holes are free and that you put the plastic cap/plug back in the front of the rocker to prevent the dirt from filling it up from the front tire spray.
Also keep in mind that nothing is perfect but if you do anything mentioned in this thread (except foam) you will increase the life of the rocker and any other part you install. Remember the factory did a very poor job of rust prevention so anything will help. Kevin LFD Inc. |
08-13-2008, 09:11 PM | #14 |
BlahBlahBlah
You would think with all the new crazy bonding agents out there you could put on a plastic rocker and just glue it. No rust.
08-13-2008, 09:35 PM | #15 |
I cut about a half inch off the bottom of the backing plates so the water can drain out ...
08-13-2008, 09:43 PM | #16 |
Built 4 Speed
THESE AINT NO SATURNS! not a horrible idea tho..*ponders*
08-13-2008, 09:52 PM | #17 |
Nothing to see here.....
pray.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
08-13-2008, 10:14 PM | #18 |
The best way I can think is every time you wash you truck, take the time and take a hose and before, during, or after the wash and spray out the drain holes til it is clear. Getting wet is no problem at all, It is staying wet.
72 Cheyenne Super 80 Silverado Blazer 2wd |
08-13-2008, 11:13 PM | #19 | |
Chevy Truck Addict
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
08-14-2008, 06:35 AM | #20 |
Also make sure your drip rails are sealed right and the kick panels are free of any blockage or dirt.
Kevin LFD Inc. |
08-14-2008, 08:53 AM | #21 |
I believe drain holes are your best bet in the rust belt.Crap will definately get in,you need to get it back out.Keeping out of salt is obvious,but there`s more.Running in the rain lets grit spray up into crevases and it lays there.We have enogh moisture in the air and condensation from the varying temperatures that will cause rust on a vehicle that`s never seen salt.
Weld-through primer is the first step,then coating after assembly,and finally allowing drainage.That`s what GM did to truck fenders and bedsides in`78 and it helped in a big way.
08-14-2008, 06:08 PM | #22 | |
08-14-2008, 06:59 PM | #23 |
72 Chevelle Club
I use a cold galvanize spray before install
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
08-14-2008, 11:34 PM | #24 |
i'm the one and only guy that didnt replace the inner rockers when fixing my rusty cab on my daily driver. and 3 years later, no problem with flex or any bondo cracking, or any problems. there's nowater/trash inside the rockers because there's nowhere for that to collect. where the cab supports reach the inner rockers, i cut larger drain holes there, and so much sand came out... anyways it seems i'm the only one doing it this way cuz it's half assed
08-15-2008, 09:37 AM | #25 | |
You are right about the cab support. When I replaced mine they were full of real fine silty sand. Rg
