Before and After
I would love to lower my 72 C20 3-5 or 4-6 ( I don't want to C Notch)if it is possible, I can get lowered springs custom made from a supplier that I use @ work, but they had a few questions about the geometry.
Front, Is there someone who makes a lowered spindle that will fit on a 3/4 ton? (it will not be hauling any weight so if a 1/2 ton will fit, what drop should be applied by the springs). Rear, How much drop should be done by springs and how much by blocks. If anyone has done this, to any extent, please let me know where parts came from and how they worked.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
Fabricate till you "puke"
spindles are available for a 3/4 ton, but a little pricey as compaired to the 1/2 ton pcs. Try to figure about 2" max on a front spring drop to keep geometry in check. At the rear, The 1/2 ton guys are going as much as 6" without a notch.....but I think I would stay with 5" on the 3/4 as max. The 1/2 ton trucks will handle about 2" of drop on a block with 15" wheels, & still be above scrub lines......you may be able to go 2 1/2" with a 16 or 16.5 wheel. check with some of the vendors on the board for spindles. Good luck...crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
There is a lowered 3/4 in a town near me. I had to look twice to figure out it was a 3/4. It had 15 inch wheels.
Buy Sale or Trade 71 3/4 4x4 72 1/2 ton cheyenne 4x4 |
Sure they can. I have reworked lower control arms with 2 in lower springs in the front and 4 in lower springs in the back. I did have to notch the rear cause I was hitting the frame.
I need to get a better picture. PS Anyone can lower a 1/2 ton!!! Last edited by Bustedup; 02-12-2003 at 03:55 PM. |
Before and After
If I use 2"lower springs in the front, without dropped spindles, how much would I drop the rear to have it sit level?
????? Springs, blocks or both ??????? I have read numerous threads and I have figured that the rear should be 1 1/2"to 2"lower than the front. Is that the idea?
4" should be pretty close.....crazyL
Early Classic Enterprises sells conversion dropped spindles along with the stock height for a 3/4 ton. These will convert it to 1/2 ton with a five lug pattern if your interested.
Check out Early Classic Enterprises
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
i love summertime
i was at a car show about 3 summers ago down in omak wa, there was a yellow 3/4 ton 4x4 early 50's ford, it was slammed...how cool is that?¿?¿?¿
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
