08-16-2008, 03:20 PM | #1 |
Sandblaster Help
Hi I have a 110 lb or 20 gal pressurized abrasive blaster .I am using Black Beauty fine media with a 3.5mm ceramic nozzle. Compressor size is 5HP 60 gal tank 12,5 cfm@ 100psi. This thing is plugging up steady I use it for 15 to 30 seconds and it plugs the media seems to be dry the water trap has no water in it I have the air setting at 125 high 75 low. Thank you for any help.8bolt.
08-16-2008, 06:11 PM | #2 |
Resident of Here
Re: Sandblaster Help
What are you blasting with Black Beauty? IO blasted my uncles wheels, chassis, and rear end.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
08-16-2008, 06:52 PM | #3 |
did you screen the material b4 putting in the blaster?// did the pressure blaster come with instructions?does it have a choke valve?if its been used before ands its a cheaper harbor frieght type the hose coud be disintagrating and causing the clogges same is true of the blasting nozzle
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 08-16-2008 at 07:31 PM. |
08-16-2008, 06:53 PM | #4 |
I had the same problem and I started sifting the media before I put it in the pressure pot. I didn't have anymore problems.
08-16-2008, 08:02 PM | #5 |
cdown it is a cheep 150.00 harbor freight blaster I pick up on holidays in Mn.I will check the hose and change the tip.
08-16-2008, 08:05 PM | #6 |
Hi fastfun what size screen did you use. Thanks 8bolt.
08-16-2008, 08:08 PM | #7 |
Sorry cdowns I forgot to say thank you . THANK YOU. 8bolt.
08-16-2008, 08:14 PM | #8 |
Hi thirdstreettito I am blasting my frame .
08-17-2008, 06:30 AM | #9 |
Rottenwood Garage Member
Mine did the same thing..........It especially clogs up when Its hot outside. Its the moisture. Put the water separator as far a way from the compressor as you can. Mine will still clogg a bit so every 2 min. I put my finger over the end of the gun and pull the trigger to back blow the media.
If I do that periodically it never cloggs.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
08-17-2008, 08:49 AM | #10 | |
08-17-2008, 08:55 AM | #11 |
If it's a pebble that clogging it then you need to sift the media or use a lrger tip. I used the same setup for my frame. The Black Beauty works well but does have a few large stones that will clog you up. The blaster will need more air pressure with the larger tip so adjust accordingly.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-17-2008, 09:47 AM | #12 |
Retired Air Force Veteran
8bolt,
I think all of the guys are right about the clogging issue. Sifting or screening your sand is definitely a must and you have to watch the moisture in the lines as it WILL clump your sand and clog your lines. I've have been having the same problems with my blaster. Get a Good Compressed Air Filter. I am now using the Motor Guard M-100. I have this setup in my garage for both my Sand Blaster and my Powder Coating Setup. I have not had any problems since.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
