Old 08-17-2008, 09:24 AM   #1
tgh117
Crazy
tgh117's Avatar
body mount differences between 73-80 and 81-87
Does anyone know the differences between the 73-80 cab mounts and the 81-87 body mounts other then the look. I am trying to decide which ones to use for my truck rebuild. I have a 77 frame, but I am using an 83 cab and front end. They are both the same price pretty much, they just seem to look different. I want to make sure I get the right ones and will be happy with the end result. I don't need them just yet, still have to yank the motor and paint up the whole frame and everything, but I will need to place the order in the near future.
Thanks for all the help.
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 08-17-2008, 09:38 AM   #2
ChaseDale3and8
ChaseDale3and8's Avatar
Re: body mount differences between 73-80 and 81-87
Get mounts for your '77 frame. Don't buy them for the body because they will be the wrong ones. The 73-80 were thicker than the 81-87 because the frames were different from 81 on. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 08-18-2008, 08:36 PM   #3
tgh117
Crazy
tgh117's Avatar
Exactly what I need to know. Thanks for the tip Joe!
Old 08-19-2008, 01:55 AM   #4
69face
69face's Avatar
the trucks have two different mounting patterns also, the 73-80 is round while 81-87 is oblong. the mounts aren't interchangeable at the core area, but the rest are.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 08-20-2008, 02:24 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The hole in the mounts are also of different size on 73-80 vs 81-87.
If there are some on the 77 chassis that is bad, get 73-80 mounts and use the same version of bushings (73-80) with you 81-87 cab and you will be fine.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
