Old 08-19-2008, 03:56 PM   #1
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Big Block Fuel line / Filter Pics at Carb?
Well After Mounting my Fuel Filter behind the mechanical pump and running into fuel starving / Vapor lock issues. (which I knew what the problem was caused from thanks to a previous post by Longhorn Man) I am Shopping around for Replacments after the pump. I would like something that looks good since I am trying to clean u[p the engine compartment, as well as works so here are a few pics and questions.
I have a q-jet does that take 3/8 or 5/16 npt?
Is the outlet on the fuel pump (stock mechanical) 3/8 npt
Should I remopved the q-jet incarb filter if I am going to run another one.
As always the help is apreceated.
What I want is something like this.
"Instructions are just another mans opinion"
Become a Supporting Member
http://67-72chevytrucks.com/vboard/payments.php
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 08-19-2008, 04:15 PM   #2
mikeoj
Re: Big Block Fuel line / Filter Pics at Carb?
Pics?
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 08-19-2008, 04:41 PM   #3
So.Cal.Super
It'll Buff Out!
This is what I would like (not sure why it didn't post the first time.)
Man Card Rules
Old 08-19-2008, 06:28 PM   #4
So.Cal.Super
It'll Buff Out!
not sure if I can connect a fuel filter with this setup
Man Card Rules
Old 08-19-2008, 06:30 PM   #5
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by So.Cal.Super View Post
Found this on jegs, looks like it might work.
ahaha, i JUST went through this. My setup is a fuel filter BEFORE the fuel pump, and there is a mini filter INSIDE the qjet. I went and bought some hardline from napa with the fittings on the ends and just bent them how i wanted em... Nice hardlines... It was 6 bucks for the hardline with the fittings. THey are 3/8 fittings on the end on the pump and carb by the way...
lyrikz is offline   Reply With Quote
Old 08-19-2008, 06:39 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it's not a good idea to put the filter before the pump. It reduces the pressure more than it has to be (it's already at negative pressure as compaired to atmosphere pressure) and the more you drop the pressure, the lower the boiling point is... which can cause, or agrivate vapor lock conditions.
Old 08-19-2008, 09:02 PM   #7
So.Cal.Super
It'll Buff Out!
Yup, I Learned this from LHM After I installed mine before the pump and it caused problems between second and third at W/O throttle and it may be the cause of another problem I am having while slowing down which is why I am on this mission.
(pic1) current filter
(pic2) current fuel line I want to replace.
Man Card Rules
Old 08-23-2008, 10:28 AM   #8
So.Cal.Super
It'll Buff Out!
ttt
Man Card Rules
Old 08-23-2008, 10:38 AM   #9
Shyguy
Junior Member
Shyguy's Avatar
I cut the metal fuel-line as it comes up from the fuel pump just in front of the passenger-side head and installed a metal in-line filter. I also took the small filter out of the carburator.
I did it a couple years ago and it is working fine.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-23-2008, 11:02 AM   #10
lyrikz
PITbut
lyrikz's Avatar
Danny
Why did you take the filter out at the carb?
My 71 has the filter located before the fuel pump. Same with the 81 i bought....
Old 08-23-2008, 11:23 AM   #11
Shyguy
Junior Member
Shyguy's Avatar
That is a good question.
It probably would have been fine to put a new small filter in the carb, but to me the pumice type filter looked to be awful restrictive.
I think it was back in '76 I did the same thing on my '72 GMC and it worked great so I figured it would too on my '71 Chevy.
Danny
Old 08-23-2008, 11:38 AM   #12
lyrikz
PITbut
lyrikz's Avatar
Danny
Mine has this little fine mesh screen in it....
SO the consensus is filter AFTER the fuel pump??? Now im wondering if i should take my filter outta my carb. ahaha
Old 08-24-2008, 12:33 AM   #13
So.Cal.Super
It'll Buff Out!
I thought it might not be good to double filter. Sounds like it works ok with it out.
thanks.
Man Card Rules
Old 08-24-2008, 08:05 AM   #14
Gray Ghost
Gray Ghost's Avatar
You are right. Had a buddy once with a BB that didn't run like we thought it might...the culprit...7 fuel filters. Yep you read that right. I'd never heard of using more than one and now I know why.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 08-24-2008, 08:45 AM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
On my blazer I run an inline metal filter BEFORE the mechanical fuel pump and a 3/8" steel line all the way to the carb. Factory Q-jet filter was removed. It's been working fine for 4 years.
Keith
Convert to disc brakes.
Old 08-24-2008, 09:57 AM   #16
LONGHAIR
The general "rule of thumb" is the you run a filter after a mechanical pump.
You run a filter before an electric pump, which should be mounted as close to the tank as possible.
LONGHAIR is offline   Reply With Quote
Old 08-24-2008, 10:45 AM   #17
kelsfine69
18 Till I Die
kelsfine69's Avatar
Mines an electric setup if that helps or not heres some pics
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 08-24-2008, 11:31 AM   #18
So.Cal.Super
It'll Buff Out!
I would bet it has to do with the style of filter and how much it filters for restriction purposes. Mine Idols great and under normal driving runs ok. But, at wide open Throttle after second gear the engine starts to bog down from vapor lock. I even have a carter mechanical which flows a bit more then stock. If I had an electric (like Kelsfine69, nice setup btw) I'm sure it would be fine. I just don't want to go that route right now.
Man Card Rules
Old 08-24-2008, 10:29 PM   #19
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
A BB definitely needs 3/8 fuel lines. I would get rid of all the 5/16s lines & small fittings.
Next I would get rid of all that rubber hose. Steel lines with open bends is better and steel braided with aircraft fittings is best.
If you have a qjet, you can run the longer fuel inlet that uses a long filter for much better filtering & flow.
PICKMUP is offline   Reply With Quote
Old 08-24-2008, 11:34 PM   #20
So.Cal.Super
It'll Buff Out!
Do you have a pic or sell them?
Man Card Rules
