Old 08-19-2008, 09:02 PM   #1
texastrendz
cannot get hood to line up between fenders
how can i get the hood to set straight in the fenders at the cowl. my hood is dragging on the drivers fender with a big gap on the passenger side. any help would greatly be appreciated, thanks fellow members of the forum.
texastrendz is offline   Reply With Quote
Old 08-19-2008, 09:14 PM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: cannot ge hood to line up between fenders
Adjust it on the hinges, You need another person to do it. Loosen the bolts then slide the passenger side closer to the cab. etc. etc.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-19-2008, 09:21 PM   #3
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
I got this tip from a fellow board member when trying to adjust my hood. With a person on one side of the vehicle and someone else on the opposite side of the vehicle, on the count of three, one pulls and the other pushes the hood toward the side that has the largest gap. This will allow the hinges to "spring" in that direction. It worked for me. It took a couple of tries, but it worked.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 08-19-2008, 09:22 PM   #4
haysonj
haysonj's Avatar
Mine was like that and I put shims between the hinge on the driver side. Still not perfect but its a lot closer.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-19-2008, 09:38 PM   #5
texastrendz
is that with the hood closed or open when you sprung the hinges?
Old 08-19-2008, 10:23 PM   #6
Botietruck
Botietruck's Avatar
That is with the hood about half open.
Old 08-19-2008, 10:31 PM   #7
Stoney
Farm Truck
Stoney's Avatar
Did You Put The Shims That Go On The Top Two Fender Bolts?
THE HINGES MOVE BACK AND FORTH ALSO
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 08-19-2008, 10:42 PM   #8
texastrendz
Re: cannot get hood to line up between fenders
uhhh, what shims, maybe that is my problem?
Old 08-19-2008, 10:45 PM   #9
Stoney
Farm Truck
Stoney's Avatar
They Look Like Front End Alignment Shims
1969 CST/10
1984 K5 Blazer 4x4
Mike
Jersey Village, Tx
Old 08-19-2008, 10:48 PM   #10
texastrendz
got one on the pass. side fender, moved it to drivers to pull it away from the hood. didnt work.
Old 08-20-2008, 11:44 AM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
How far has your truck been taken apart? There could be a host of problems that could be giving you trouble.
1.) Is your cab square on the chassis?
2.) Are your hinges worn out?
3.) are the front fenders and core support square to the cab?
You might try loosening the core support bushings and pushing the front fenders and core support toward the driver's side.
If your hinges are worn out then you will fight them untill the cows come home and still not get it right. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-20-2008, 07:08 PM   #12
mbgmike
I agree 100% ..you have to check the squareness to get the front end correct. We sometimes even loosen the front cab mounts to line things up.replacing front ends rarely are just "bolt new parts back on."This is true on old trucks and late model to. Check you diaginols from a point on the firewall to the same point on the front. should be damn close. 1/4 " off is generally ok. Get the cab square and you can also see any front frame damage easier also.
Mike
mbgmike is offline   Reply With Quote
Old 08-20-2008, 07:12 PM   #13
mbgmike
Did not realize that you are in Houston. Bring it by the shop and (THe other MIke ) our body shop manager can show you how to line it up.
There is generally someone here around 8am to 8 pm most all days
Old 08-20-2008, 09:52 PM   #14
texastrendz
finally got guys, took a little bit of all your ideas, boy let me tell yea, your better of buying old o.e stuff then the after market. had to alot trimming here and there with alot of whole opening up, lines are not perfect from o.e to aftermarket, but i am not building a show truck. once again guys thankx, this forum really does help to get ya on the right track.
