08-19-2008, 09:51 PM | #1 |
Another Stupid PO
While removing several pounds of filler on pass side I discovered a patch over the wheel arch. The patch did not have the small crease around the edge of the opening. They used that patch and filled the original crease with filler to make it look the same. My question is where or what would that patch be from? Going to try to borrow a pic from AJs72K5 from last Stupid PO. The crease is the small indent around wheel opening.
08-19-2008, 09:58 PM | #2 |
Re: Another Stupid PO
Sorry AJ hope this isn't a copy right infringement, with pic if so come get Blazer you would save me lots of $
08-19-2008, 10:12 PM | #3 |
No worries. I opened the thread and was like, "Hey! That's me!"
08-20-2008, 07:27 AM | #4 | |
This part maybe? |
08-20-2008, 07:39 AM | #5 |
Yes, There is a small crease all along the edge of the opening just before turning into the inner wheel house on the rear and before the inner fender on front. The patch didn't have that small profile like the original. Wondering where it came from.
08-20-2008, 08:12 AM | #6 | |
(if I'm understanding you correctly that is) |
08-20-2008, 05:41 PM | #7 |
Hope this will clear up what I am trying to explain, the profile on the original is circled in red. Hard to tell with pics but looking close you might be able to tell where patch starts without profile. The original (darker shade) is about where the splash guard is, above and below that is the patch without profile.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat Last edited by Bentblazer; 03-08-2011 at 09:30 AM. |
08-20-2008, 07:07 PM | #8 |
Yep, nothing reproduced like that.
Put a WTB thread up in the classified section looking for a patch area from an "original" fender and you'll find yourself one. Gotta be a subscribed member though... |
08-20-2008, 10:51 PM | #9 |
That's really weird. Because my PO told me both front fenders had been replaced when he was making it over due to rust. I assumed aftermarket (LMC) but could be wrong.
08-20-2008, 11:05 PM | #10 | |
Actually no, some patch panels do come with the detailed lip, only the really cheap stuff doesn't have it. |
08-21-2008, 07:15 AM | #11 |
08-21-2008, 07:18 AM | #12 |
08-21-2008, 07:47 AM | #13 |
Early this spring I bought a swb bed side (drivers) that I cut to replace original and it had that indent on it. I got it from Manes. Does a LWB wheel arch measure the same? I have a LWB bedside that I could cut for patch if needed, but wanted to check for new first. Would hate to have to fill indent on new side If I could repair original since forth fronts and driver look same.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
08-21-2008, 09:08 AM | #14 |
They make a patch for the rear wheel arch with the indent in it. And yes the LWB arch would be the same.
MOST Tri-plus panels have the detail but you may get a bad one, depends who you buy from it seems. Another brand I came across with it was Tabco. Anyone that wants picture proof of the detail on the rear arch I will PM the pics. Oh yah and I have GMC repro front fenders that have the indents also. Last edited by 69-72; 08-21-2008 at 09:12 AM. |
08-22-2008, 10:01 PM | #15 |
So do you think it would be better to cut a patch out of the LWB or look for a repop patch?
08-22-2008, 10:23 PM | #16 |
isn't the rear arch of a SWB and LWB different? I thought that the SWB "swept" out more in the rear of the arch. Not sure what your blazers do but be sure to check...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-23-2008, 08:56 AM | #17 |
Orignal metal is always better IF you can find it, but when I was matching up the creases from the repop panel to the orginal it was pretty darn close. The rear arches on LWB, SWB and Blazers are all the same.
08-23-2008, 11:50 PM | #18 | |
-Lincoln 1987 GMC S15 (soon to be a chevy clone) 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. Spoken by Cletus the hillbilly I like stickers... a whole bunch. |
08-24-2008, 08:57 AM | #19 |
I can see the difference in the photos, the patch I need will run from near the moulding on the front around to the rear to the bottom, Think that would work?
08-24-2008, 11:41 AM | #20 | |
I am referring to the upper piece, the actual arch area. Last edited by 69-72; 08-24-2008 at 11:42 AM. |
08-24-2008, 03:04 PM | #21 |
The pic you have shown is what I have to replace, but would like to continue on to the rear bottom as a small patch wa placed there also. The idea was to replace two patches with one. It does look like that the forward bottom looks different however I don't need to go that far down,
08-24-2008, 10:28 PM | #22 |
Yes from the front belt line molding up around to the rear arch bottom they are all the same. The differance is in the lower front corner of a LWB to a SWB/Blazer. So it should work fine depending on your skills.
Kevin LFD Inc. |
08-24-2008, 10:56 PM | #23 |
Keepin it runnin!
Tabco's panels (the ones THEY make) have that detail perfectly. I ordered the patch panel for the area forward of the wheel well on the rear qtr panel and it came with the detail (very crisp) and a nice heavy galvaniel gage steel! I suggest calling before ordering and specifying that you want their parts only, because they do sell some inferior parts too. I'll try to get some pics....
Frank
1970 K-5 4X4 Blazer 1970 K-20 4X4 Long Bed "Liberty Means Responsibility, that is why most men dread it" |
09-04-2008, 09:01 PM | #24 |
Located a patch panel with indent from a board vendor last week. On vacation this week and due to Gustav remnants I was confined to the spousal avoidance center and try my luck at installing. I'm not much of a welder so those who are my hat is off to ya. The small patch with green was off of a donor lwb bed, the black patch was the repop. The last is next to replace just had to show how much filler was used, nearly a half inch thick. Feel free to give advise it is appreciated. On a lighter note I took picture of a lake that I had dug in July, yesterday this lake had only a foot of water in it and thanks to Gustav twelve hrs later and 6.5" of rain its more than full.
09-05-2008, 09:58 AM | #25 |
Looks good. How are things in Rolla since B&S left? I hated that, a lot of good guys worked there...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
