#26 |
Gettin By on Gettin By
Re: How I did rear axle seals, bearings, brake shoes & cylinders
Now thats some fun work.
Funny, but my rear cylinder had the same problem, i had to trim it off to make it fit.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
#27 |
If I did all that for you it would have cost about $200 plus materials. That would NOT have included spic-n-span parts or new paint. You were only about 30 min. worth of work to go ahead and change the pinion seal while you were in there. Just have to be careful not to overtighten the nut when you put it back together.
#28 |
hmmmm - I haven't seen a good write up on that one so I didn't go for it (I need pictures with fingers pointing at stuff and step by step
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
#29 |
If you look in my build thread you will see pics of the pinion seal, I changed it...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#30 |
Tasty Cakes!
Nice write up. I had the same problem w/a wheel cylinder from China. Bought mine from Napa and one was made in the USA and one was made in China. The USA one went right in no problems. The China made one was cast wrong (like yours.) I took it back and got another USA one (they had more in by then) and it went in no hassle.
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
#31 |
yeller
I know this is an old thread..but I am in the middle of the same thing on my '75 12 bolt. I however, did drop the smal spider gears when I rotated the driveshaft to remove the pin. Any special tricks to getting everything back in...it looks like I just need to work them back in as I re-insert the shaft. Thoughts? Waiting for by backing plates (and drums) to come back from the powdercoater before I can re-install the axles...just trying to prepare myself.
Nice write up!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#32 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Putting the spider gears in seems daunting till you figure it out. Basically, you have to hold the front and rear gears in place and they have to be directly opposite of each other. Then roll them in. My words don't convey it, but once you get under there and try to install them it will clear up some. Just remember they have to be directly across from each other and both installed at the same time. If you don't have them directly across from each other, the pin hole will never line up.
But once you figure it out the first time, you'll never need more than 10 seconds to install them in the future.
#33 |
Great info. Just about to do same job. Thanks for pics
JR |
#34 |
This is just a first-class write up, which will make it super easy for the rest of us to tackle this work. Thanks, even though it is a very old thread.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
#35 |
