Old 08-20-2008, 01:23 PM   #1
mrein3
mrein3's Avatar
Snow Plow Question
Hey snow plow guys - I have a question. I want to outfit my 1971 4x4 chassis with a used plow off craigslist or similar.
What years of Chevrolet are "bolt-on"? Just 71 & 72? Up through 87? Through current?
I'm tired of shoveling/snow blowing my driveway. Winter isn't that far away. Please help.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-20-2008, 02:33 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: Snow Plow Question
You answer may vary depending upon the manufacturer. My experience is with Fisher plows. The push plates are engineered for the application and unless the 73-87 frames (cab forward) are identical to the 67-72 frame you will have issues. Even if the frame is the same you may still have issues with clearance of bumpers and grille. Obviously some parts are 'generic" such as the valve body, hydrualic pump, cables, and hoses. Engine brackets for the pump vary by engine size, can not answer if short/long water pump altered the bracketry or not. Your best bet is to find a setup for the correct year(s). Better yet, purchase a complete setup already installed.
Your area seems to use Western plow brand. Someone running that setup may provide a totally different scenerio.
Good luck.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 08-20-2008, 03:48 PM   #3
mrein3
mrein3's Avatar
I guess that is the question.
Is the frame on a 71 & 72 4x4 the same as 73-87?
Craigslist is loaded with 73-87 (mostly 85-87) plows. None 72 & older.
I'd prefer to NOT have an engine mounted hydraulic pump. Don't the new systems have electric pumps?
'72 Malibu hard top
Center City, MN
Old 08-20-2008, 04:18 PM   #4
woodridge
woodridge's Avatar
I sold Meyers plows in 92-93 and at that time they still listed mounts for the 67-72's. The 73 up frames are similar enough that it shouldn't take much mods to make it work. The systems are self-contained and no need for an engine driven pump.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 08-20-2008, 07:45 PM   #5
JimKshortstep4x4
I am installing a Western plow on my current plow truck that I am building using a Blazer frame with a cab on it. I am running into a clearance problem with the grill so I have moved the carriage forward. I will have to drill different mounting holes for the lower brackets but overall it looks like the Western plow from a 79 4x4 can be made to work with the two mods mentioned.
The width is right for the frame and I will be able to use my Meyer blade on the Western carriage.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-21-2008, 08:29 AM   #6
mrein3
mrein3's Avatar
Jim
Thanks everybody for your replies. I now have what I needed to know.
'72 Malibu hard top
Center City, MN
