Old 08-20-2008, 02:19 PM   #1
BluTrukker
BOHICA
BluTrukker's Avatar
Rims, or Axles?
I have a real nice set of 5 bolt centerline wheels with brand new tires on them from another project. I would like to use them on my 68 C10 2WD. The problem is my truck has 6 lug axles. Would it be cheaper to find new hubs&axles, or buy new rims and tires. If I could find a donor vehicle, do 5 and 6 lug axles have the same number of splines/length/ diameter? What years/model would be a direct fit? If the answer is no to all, does anyone know where I can get reasonably priced new/used 6 lug wheels? Any info would be greatly appreciated.
BluTrukker is offline   Reply With Quote
Old 08-20-2008, 03:06 PM   #2
nightmare
nightmare's Avatar
Re: Rims, or Axles?
well, there are lots of factors to consider. first off, what size bolt pattern are the centerlines? If you aren't sure, what were they on previously?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 08-20-2008, 04:43 PM   #3
BluTrukker
BOHICA
BluTrukker's Avatar
Re: Rims, or Axles?
they came off of a 1980 Z28 camaro
Old 08-20-2008, 05:46 PM   #4
nightmare
nightmare's Avatar
Re: Rims, or Axles?
Well, for those, you may want to just buy some adapters, since the bolt pattern of those are 5x4.75. just look for some 6x5.5 (IIRC) hub to 5x4.75 wheels. Adapt-it appears to have these, but they look a bit pricey to me. maybe try summit or one of the board vendors.
Mike
67-72 FAQ
Old 08-20-2008, 07:03 PM   #5
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Re: Rims, or Axles?
Late model 6 lug Chevy trucks use the same bolt pattern as the 67-70 trucks. You could probably find a set of stock or aftermarket wheels at a junk yard that would work.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 08-20-2008, 09:39 PM   #6
nightmare
nightmare's Avatar
Re: Rims, or Axles?
that is if you want to keep those rims. if you want to get some others, Old Yeller 1970 has a good idea
Mike
67-72 FAQ
Old 08-21-2008, 08:01 AM   #7
BluTrukker
BOHICA
BluTrukker's Avatar
Re: Rims, or Axles?
I searched all over the web, and the only place I could find adapters for 6-lug was adapt-it. And you are right, very pricey. It looks like my best bet is gonna be new wheels. Thanks for all the help.
