How do I remove the parking light assembly???
I have a 66 GMC with turn/park lights like this:
![]() How do you take these out? Do they pop out the front somehow? There doesn't appear to be anything on the backside that I can unscrew. I know it's probably in my assembly manual somewhere, but I can't seem to find the detail of what holds it all in place. Can anyone shed some light on this? hopelessly confused in houston
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster |
1961 crewcab
Re: How do I remove the parking light assembly???
go to www.6066gmcguy.org/ he has a detailed explanation on how to remove them.
if you look insidethe hood there are 2 spring steel clips spot welded to the housing that you have to press down and push out. |
Rust Buster
If you are not re-using them, a #2 BFH will remove them real quick!
![]() Join Date: Nov 2006
sorry, they're non removable... just send your hood to me... I'll take care of it.
Thanks, I see how it works now.... I'm not liking it..... but I see how it works. What a PITA..... I'll come back to it later.
1961 crewcab
Park Lamp Removal
Has anybody found an easy way to remove these lamps from 1962 to 1966 trucks? The hard part is holding down both clips on one side & pushing the lamp out at the same time, need more than three hands for this, right? Well try this, Fabricate a tool out of 1/4-inch square steel stock (bar stock) to the dimension shown in this scan. You will need to build this tool. To remove lamp assembly, raise the hood, (duh), & remove the bulb-socket assembly. Insert tool under the two lower retaining clip, & force handle of tool downward & at the same time exert pressure (Hit Hard) on lamp body to force lower portion from hood opening. (see pic) Be careful removing the tool as you will pull the lamp back into place, there is not much room & you need to get it out on the bottom before you can get the tool in the top. Now insert tool in the same manner on the top of the lamp, but pushing upward, push lamp from hood. Cool eh? this is right from the GMC Manual, well most of it. © 2000-2005 6066 GMC Trucks. Last Updated April 18, 2005. Last edited by jonzcustomshop; 08-24-2008 at 05:50 AM. Reason: cut and paste didnt work out like I expected! pics in my next post. |
1961 crewcab
I was able to use a screwdriver at the wrecking yard, but it was real hard...
