#51 |
Re: Post Your 60-63 Body Style Chevy/GMC Trucks
1Bad62Pro/Street, i was wondering what happened to ya.....haven't seen ya in a while...
![]() bazooka, love the truck!.......hate the clown! brawley, yes the mounts are different....but it is only metal.....you can make it work
#52 |
1961 crewcab
hey! lucky you!
I would love $3.85 a gallon we are paying $4.06! |
#53 |
WOW! ours has gone down....we are in the mid to high $3.30's
#54 |
chevy only
![]() Join Date: Sep 2006
jonz is your truck running and driving? looks slick , always nice job
CHEVY ONLY... Nothin Else ! |
#55 |
$500 score only had it a month.
![]() just got all my 2.5" drop spindles and disk brake conversion. ![]() camera sucks!
-61 c10 short step -67 c10 short step -71 k10 long fleet -77 k20 long fleet (gettin all the goodies from frankentruck) -79 c30/k30 3+3 frankentruck (cab and frame for sale) -99 GMC yukon daily driver |
#56 |
1961 crewcab
Dino-I had it out last weekend to our car show.
check out my build thread for more shots. I was running some RARE $2.90 gasoline ![]() ![]() |
#57 |
Keepin it old school
you guys got it easy its 4.29 for the 87 where I live..4.59 for the 91...The price has came down to in the past few weeks too
![]() Last edited by Bazooka; 07-31-2008 at 12:58 AM. |
#58 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
Moved back home to NC in March, and been working six days a week ever since. Man I hope to get the chance to fire my ole' Beast up and drive her on the road. Probably have to fresh'n her up first. Check the Brakes, tires, and everything else before I put a tag and insurance back on her. NC taxes and fees are Expensive on everything!
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#59 |
Just here to tinker
![]() Join Date: Jun 2008
Here is my '60....
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#60 |
![]() ![]() ![]() Wanted a 60-66 'burb or panel truck for several years now, (owned a rusty 1989 'burb for 5 yrs now, love the hauling capacity) after seeing a previously abandoned project purple '64 "not for sale" in a boneyard several years ago. Working my tail off for the past year remodeling our dream house (massive 3 story 1890 brick victorian), got this as a suprise 30th birthday present from my awesome lady, Jenn, in gratitude for all the hard work... The 71 RS/SS Camaro project will remain in pieces for a few more years while I swap parts off another 89 'burb - front end for disc brakes, 89 power steering using the Rez adapter plate kit, power brakes, possibly rear end (GMC Dana 44 rears are far superior to 10/12 bolts, but parts are rare), Tremec 3550 5 speed, 5 lug Torque Thrust wheels, stock or slightly lowered ride height with progressive rate springs (need to haul/tow still, might do some additional air shocks and keep at 0psi when not hauling), F#$d Taurus electric fan, big 2 wire alternator swap (has generator/regulator still), etc... Got a lot of the bugs worked out of this basket case already, still working on more. Got a custom HEI distributor for it, 8mm plug wires, some fancy spark plugs, machined out the carb bore of the intake to bolt on an adapter to run a Holley 500cfm carb, oil bath air cleaner was already gone, and it already has dual exhaust (almost bone stock and original otherwise, plus wheels/seats/2 paint jobs/new bed wood). GMC big block V6's are hard to get parts for! Not so much a hot rod engine (no real aftermarket parts, & has a truck cam), that's what the Camaro is for, but want it to run good, and try to break 17mpg highway. The GMC big block V6's are hard on gas (massive bore and ancient combustion chamber/port design), but dead reliable, last 200-300,000 miles, TONS of low end torque (doesn't rev very high though without), and strong as hell. Dual exhaust, HEI ignition, and a 500 cfm holley 2bbl REALLY wake them up though (and rev higher). Custom ground cams are available that will make it have more upper end street power. Still, they're a bit heavy, and hard on gas, so when I scrap the rusty 89 body when it's completely gone, I might might save the GREAT RUNNING 270,000 mile 350 TBI setup and swap the computer/TBI or the whole engine plus vortec heads some day, if gas prices get any worse. that 350 in a 5200 lb truck gets 22 mpg highway with cargo last I checked! in a 4100 lb panel, with vortec heads, it should do the same easily despite the additional aerodynamic disadvantage. The GMC engines are awesome other than the gas mileage, order-only parts, and to a lesser extent, the 200 lbs extra over a 305 V8. When the 89 body goes to the scrapyard, I'll be saving the whole engine/trans (700R4 as spare), computer, front end parts (for the other 89 front end I'll put on it for discs and cost/availability of rebuild parts), brake parts, rear end, and gas tank to possibly swap into over time. Gonna give the 305 V6 a long trial first, as it's original, and I have no time to even swap the front end and tranny for now! a TBI swap would be a challenge (intake!), but may be worth it. I've heard of two others doing it on the GMC V6's, but no details. Oh yeah, probably also doing some solid del-a-lum a-arm bushings if Global West or someone makes them for the 89 front end, poly body mounts, maybe even bigger than the stock 89 sway bar, and a third gen Camaro rear sway bar with some spacer blocks to make the frame mounts work. It'll no longer drive like a tractor, but more like a sport truck! Paint looks good from 20 feet, but has some rust bubbles low and on the hood (by bracing) and on the fenders low (same as hood, collected leaves and squirrel nest debris over time and rotted!). I'll touch it up for now, rat rod and daily driver style. It's a truck, a bit of a rod, but it's gotta function as a truck and look b@d@$$ to boot... Chuck in Ohio 1962 GMC 1000 Panel Last edited by Chuck78; 08-01-2008 at 06:53 PM. |
#61 |
Heres a picture of my 61 Chevy with a 235 6 cylinder and 4 speed. Torison bars lowered all the way and 5 inch rear lowering springs. The rear gears are bad and am looking to replace the rear end with taller gears.
1950 Chevy 1/2 ton 283 Mustang II 1961 SWB 2x4 235 six 2007 Silverado 1/2 ton Z71 4x4 1968 Camaro SS 396 / 502 |
#62 |
100% gearhead
Here's an updated picture of the ol' 62. I change colors on this thing like underwear.
#63 |
1962 C-10
Your '62 is sick! I love it...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
#64 |
1961 crewcab
I still like the purple the best imperial...
is it channeled, or are those suspension mods? |
#65 |
Love the 62!!!!!!!!!!!! I wonder why?????
#66 |
1966 Chevy/GMC Mongrel K10
Cool chick ![]() |
#67 |
#68 | |
i love it!!!
#69 |
Project: "Full Metal Yellow Jacket" is getting revived again.
Uncovered Ole' "Project Full Metal Yellow Jacket" the other day with plans to get her back on the road for now. Took the Bed off with intentions to buy a 55-66 Chevrolet Truck Fiberglass Stepside Bed 6' - (Tubbed Heavy Duty) from USBody. ![]() I am also want to get a pair of Fiberglass doors from http://www.usbody.com/Pages_Trucks/60-Chevy.htm to make suicide doors on my truck. I also am working with my dad on engineering a Coil-over, 4-Link rear suspension on her. Yes you can buy a kit from Heidt's Classic Truck 4-Link Kits...but I'ze Poe! http://www.rjays.com/Classic_Truck/rr-susp-01.htm Lord willing, I will finish her soon one day. There will be updates and pictures on here on her as the progression goes on. Keep the pics coming! We all on here like looking and other fellas Trucks for ideas, inspiration and motivation. I have had my truck since I was in high school! I am 32 now......By the Grace of God.........I will "GIT -R- DONE!!!!!" With God, all things are possible ... I have a sound clip of her when I fired her up....,But don't think I can upload it on here...
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 08-23-2008 at 09:42 AM. Reason: Grammer and Spelling errors |
#70 |
1961 crewcab
that stepside sure hides that big footprint!
You're taking the road I wanted , an all glass 60-66 with veteatr on the plates. |
#71 |
Yep....... Sure does! Like Big Foot!
Wish I had fatter hides in the back. Like, 31x18.50!! Well, guess you can say, "Baby got Back!"
#72 |
![]() Join Date: Apr 2007
Matts & Mortons 1963 c-10 shortfleetside(LILBLUE) under construction!!
![]() ![]() ![]() ![]() Last edited by 283 Man; 10-09-2008 at 07:18 AM. |
#73 |
edited
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 09-22-2008 at 10:31 AM. Reason: Adding stuff, and what have ya.... |
#74 |
edited
#75 |
edited
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by Liz; 09-22-2008 at 11:13 AM. Reason: fs |
