Old 08-23-2008, 12:40 PM   #1
Nima
Blue 67
Pitman and Idler arms
Hey guys:
What are the signs of worn pitman and/or idler arms? Can you check them when the front end is up on the jack stands?
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 08-23-2008, 05:11 PM   #2
Wrenchbender Ret
Re: Pitman and Idler arms
Yes. For the pitman arm move the steering column back & forth a little. Watch the joint in the arm. There should be no lost motion. For the idler, grab the right wheel & pull from side to side. Ther should be no up & down play. Grab the center link & try to pull up & down, or use a pry bar. There should be vno up & down movement.
Wrenchbender Ret is offline   Reply With Quote
Old 08-23-2008, 05:20 PM   #3
Nima
Blue 67
Thanks for reply. When I said the front end is up on the jack, I failed to mention the front end is all apart!. I am rebuilding the front end therefore there is no wheel or tire, as a matter of fact no A-arms to grab!.
Old 08-23-2008, 11:37 PM   #4
RaceAGMC
RaceAGMC's Avatar
Depending on the rebuild kit you buy it may come with both. The kit i got from CPP came with one, just can't remember which.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 08-24-2008, 12:31 PM   #5
Wrenchbender Ret
You can clamp the stud in a vise. The stud should tightly & have no back & forth movement
Old 08-24-2008, 12:54 PM   #6
steelhorse
steelhorse's Avatar
If it is already apart just go ahead and replace them they dont cost that much.The extra piece of mind is worth it.
steelhorse is offline   Reply With Quote
