08-23-2008, 08:37 PM | #1 |
Resident of Here
Spot Welder
Who makes a good (cheap in price) spot welder/dent puller kit? I need to remove some dents soon so I want to know.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
08-23-2008, 09:54 PM | #2 |
Re: Spot Welder
harbor freight has one for under 100bucks
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 http://i195.photobucket.com/albums/z...en58/001-2.jpg |
08-23-2008, 09:56 PM | #3 |
Resident of Here
Re: Spot Welder
Does it work good? Is it worth the $$?
08-23-2008, 10:20 PM | #4 |
Active Member
Re: Spot Welder
Re: Harbor Freight.
I had one a long time ago that my brother gave me and it wasn't that good. I'd save, scrimp and scrounge and get a decent one. I'm doing that to get a Lincoln 175 or a Hobart from Tractor supply. Of cours a Miller would be the ideal but on a retirement income I have to watch my pennies... I'm planning on spending $500 to $600. Gotta remember that after that you still have to get the accessories and that will probably add another $300 to $500 dollars. |
08-23-2008, 10:24 PM | #5 |
Re: Spot Welder
He's talking about a stud welder not a spot welder I think.
It welds pins onto sheet metal and comes with a slide hammer to pull dents right? if so then i'm looking to pick up the Harbor Freight one since I only need to do my cab and doors...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 08-23-2008 at 10:24 PM. |
08-23-2008, 11:09 PM | #6 |
Active Member
Re: Spot Welder
Ooops. Read it wrong...
08-23-2008, 11:38 PM | #7 |
I have a radical idea!
Re: Spot Welder
I have the one from Harbor Freight. It is made by Chicago Electric and works very good. I have used several times with no issues.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-24-2008, 12:08 AM | #8 |
Resident of Here
Re: Spot Welder
So you guys think I should get it? I need it for the cab dents. C-30, got a link to your kit?
And yeah I meant stud welder, couldnt remember the name. Where do I buy the sticks?
08-24-2008, 12:11 AM | #9 |
Re: Spot Welder
Here's the link.
http://www.harborfreight.com/cpi/cta...emnumber=98357 It comes 100 of each size studs, so I haven't had to buy any yet. I'd say go for it. Its something that you can use a long time if you take care of it.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 08-24-2008 at 12:12 AM. |
08-24-2008, 12:15 AM | #10 |
Resident of Here
Re: Spot Welder
Thanks C-30!
How do I take proper care of it? What do you use different size studs for? Oh and it says, 300 studs.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck Last edited by thirdstreettito; 08-24-2008 at 12:16 AM. |
08-24-2008, 12:23 AM | #11 | |
Re: Spot Welder
The different sizes are for different thickness metals. I use the smallest on regular sheet metal like on the body panels of these trucks.
08-24-2008, 02:00 AM | #12 |
Re: Spot Welder
chicago makes a good grinder from harbor freight. i had one that lasted 3 years, and it was like 30 dollars. i dropped it so many times and put it through hell. so much bondo dust got in there, but it always worked. then recently the bearings kinda crapped out and it made an awful noise and didn't catch/spin the disk.
08-24-2008, 10:34 AM | #13 |
Resident of Here
Re: Spot Welder
Yeah we have an electric 5 1/2" grinder. Cost quite a bit.
08-24-2008, 11:11 AM | #14 |
Re: Spot Welder
oh i had the 4.5 inch
08-24-2008, 11:30 AM | #15 |
Resident of Here
Re: Spot Welder
Ours isnt Harbor Freight. Thats why it cost quite a bit.
