Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 08-24-2008, 10:08 AM   #76
ed2552
ed2552's Avatar
Re: 65 C60
Originally Posted by 60-66 Nut View Post
The reason they said you would have to change the wheels is because those are the two piece wheels, not to be confused with lock-ring type wheels like mine has, which are still used alot today, and are fairly safe as long as the wheel and locking ring are not badly rusted or bent. The wheels on your truck actually come apart right down the middle of the wheel in two almost equal halves. They are extremely dangerous, even just to air up a low tire so be very careful. These are the wheels that coined the name "killer wheels" or "widow makers". They have injured or killed many people, which is why most states have outlawed them all together.
I know that, and that is fine with me, we got brand new semi tires on there, LOL. I know they were extremely dangerous, and it is illegal to put new tires on them or fix tires on them, which is why we had to get new ones. I will post some more pics of the new wheels and tires soon.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 07-06-2009, 12:22 PM   #77
abilityonline
Re: 65 C60
Guys,
I've got a 68 c-50 with split rim "widow makers" on the rear axle. The tires are 8.25 x 20. What rims can I replace these with, nobody here in Utah will touch them. Can I use the existing tires I have with innertube on the new rims? If anyone has done this before please give some input
abilityonline is offline   Reply With Quote
Old 07-09-2009, 08:09 PM   #78
ed2552
ed2552's Avatar
Re: 65 C60
I'm not sure you're going to find a 20" wheel for that bolt pattern. We got semi-truck 22.5 steel wheels and Bridgestone V-Steel semi tires. Cost $1k, but we'll never need front tires again.
Old 07-09-2009, 09:11 PM   #79
70 Suburban
Rods
Re: 65 C60
you could have or can get 22.5 alcoa aluminum simi wheels and have them turned down to 22. then u can get street tires in 22.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 07-09-2009, 10:12 PM   #80
ed2552
ed2552's Avatar
Re: 65 C60
That would be even more expensive. Our wheels were $250 apiece as were the tires. I'm sure Alcoa alum's are $500+ apiece. Plus, it's on a C50 anyways, he's going to want the load capacity of the semi tires. It does have the large 5 bolt pattern, correct?
Old 07-09-2009, 10:35 PM   #81
70 Suburban
Rods
Re: 65 C60
they sell adapters on egay for them to go to 10 or 8. you can call Goodyear of someone like that. they are not that bad at all or the local salvage yard(big truck) they sell them also. When i worked at penske I think I could get them for 150 200 each. I was going to do this for my dad on his 73 one ton. dully
Old 07-09-2009, 10:48 PM   #82
abilityonline
Re: 65 C60
local truck tire garage had semi rims that fit it like a glove. 3 of the 6 tires are now on the upgraded rims. I'll swap the last three when the tires wear out.
Old 07-09-2009, 10:55 PM   #83
70 Suburban
Rods
Re: 65 C60
sweet
Old 07-10-2009, 08:04 AM   #84
ed2552
ed2552's Avatar
Re: 65 C60
We were told on the rear that if/when we have to replace one rear tire, we have to replace them all, as they can't re-mount these wheels apparently. The rears have tons of tread, so I hope we don't get a flat, lol.
Old 10-26-2009, 09:26 PM   #85
sailed2japan
Jonny
sailed2japan's Avatar
Re: 65 C60
I wish those pics hadn't dissappeared....
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 10-27-2009, 11:57 AM   #86
ed2552
ed2552's Avatar
Re: 65 C60
Oops, I moved them in my PB. I'll fix the links, as well as add some new pics.
Old 10-31-2009, 11:22 AM   #87
ed2552
ed2552's Avatar
Re: 65 C60
Pics Updated. Also hauled 2 loads of scrap with it in July. First was gates out of hog barns, and they weighed almost 6 tons, hauled another load of 3 tons of steel. About $600 of steel at $75/ton.
Old 10-31-2009, 06:40 PM   #88
JaggedEdge
JaggedEdge's Avatar
Re: 65 C60
wayyyyyy late (as usual) but hey the thread came back to the top so I looked in.
Nice truck..excellent score!!!!! You don't see many in THAT good of condition. Wish I had that cab. Wait... I wish I had the whole truck!!!
JaggedEdge is offline   Reply With Quote
Old 11-01-2009, 12:28 AM   #89
sailed2japan
Jonny
Re: 65 C60
yeah! I got to see how nice your truck is. I'm kinda on the hunt for one right now as my plans for my profect change whenever I see something I like. Now I've got it in my head to get on of these beasts to use as a base for my crew cab build. How cool would one of these be with a crewcab, big window, cummins, and a 10 speed? And it would have to be set up with air suspension and a fleetside bed with step side fenders added one....oh, and the bed would have to dump, can't have a big truck w/o a dump bed....anybody wanna sponsor this?
-AEC Hundley USNR
Old 11-01-2009, 10:41 AM   #90
ed2552
ed2552's Avatar
Re: 65 C60
Haha. Umm, this truck is staying here....
Old 11-01-2009, 10:47 AM   #91
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: 65 C60
Pics of it now?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-01-2009, 01:56 PM   #92
sailed2japan
Jonny
Re: 65 C60
I've been cruising the net for one and saw a wrecker with a BBW! I didn't think they ever made heavy duty trucks like that. Anyway I'm on the hunt now, just might make a kill. If you have a minute can you measure from the back of the cab to the front of the rear wheels? I'm woondering how much room is in there.
-AEC Hundley USNR
Old 11-02-2009, 12:55 PM   #93
ed2552
ed2552's Avatar
Re: 65 C60
Every truck is different, depending on the bed that was put on. GM made one chassis and the coach builder cut and welded in frame extensions to make their bed fit.
Tito, the only thing different that you can see on the truck is the wheels, and right now it's in the shed, behind a bunch of tractors. If I get it out to change the oil before winter, then I might get some pics.
Old 11-02-2009, 06:50 PM   #94
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 65 C60
almost al wreckers, and tow trucks were big back window, for visibility...
check out www.6066gmcguy.org/ for frame length for the bigger series trucks, there were quite a few.
.... and check out this for inspiration
Old 11-02-2009, 11:25 PM   #95
sailed2japan
Jonny
Re: 65 C60
That's some pretty awesome inspiration. I've got to thinking about this since I've already seen a couple crewcab c10's running around the forum, which would make mine be another in the crowd. I've also thought of doing a Long Bed dually
-AEC Hundley USNR
Old 10-19-2010, 12:43 PM   #96
wes wakefield
Re: 65 C60
does anyone have a manual know anything about a schwartz t60 hoist ????? a manual for one would be great
wes wakefield is offline   Reply With Quote
Old 10-19-2010, 12:45 PM   #97
wes wakefield
Re: 65 C60
I have a 1965 c60 dump with that model hoist, and the company is out of business and having a real problem locating any literature on the hoist
Old 10-19-2010, 01:10 PM   #98
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 65 C60
Edit - posted in wrong area.
