Old 08-24-2008, 06:07 PM   #1
dhughins
dhughins's Avatar
differences in 1/2 ton and 3/4 ton
i just got my 64 home and decoded the vin to be a 3/4 ton what can ya'll tell me about it?
dhughins is offline   Reply With Quote
Old 08-25-2008, 12:53 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: differences in 1/2 ton and 3/4 ton
Heavier frame and suspension. 8 lug wheels. A full floating differential. The stock differential is a 10 bolt HO52, usually 4.10 or 4.56 gears. And there aren't any better gears to upgrade to, so if you want a highway truck you need to either put in an overdrive tranny or a newer differential.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 08-25-2008, 07:52 AM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I think the rear cabmounts might be a different item (still in the same spot) I think the heavier trucks had vulcanized rubber mounts.
From your pics, it looks to have a 5 or 6 lug wheel. which means that your frame is a 1/2 ton, I wonder if the frame and box are from a 67-72?
you can check out the left front frame rail , right about where the #1 spark plug on a v8 is, for the vin # , then you can see if the frame/ cab is switched out.
My 60 is a 3/4 ton, but I have changed everything on it, it is now lighter than a 1/2 ton, but I went ahed and still registered it as the 3/4 -it's only an extra $5 tax- rather than try to explain to the dmv what it is now...
Old 08-25-2008, 05:59 PM   #4
dhughins
dhughins's Avatar
the vin on the cab and the number on the frame match. so i'm confused. if it's a 3/4 ton which the vin is #25 why does it have 6 lugs and swb. aren't all 3/4 tons lwb? could the frame have been shortened? does this pic help any?
Old 08-25-2008, 10:02 PM   #5
jonzcustomshop
1961 crewcab
they did not make a 3/4 ton swb, so check in between the rear and tranny for welds where they might have shortened the frame.
It is easy enough to un bolt the suspension and replace it with 1/2 ton stuff, so that is what might have happened.
does the gvw tag by the left kick panel say 2500 lbs?
are you sure that the vin is for a 3/4?
Old 08-26-2008, 06:33 AM   #6
dhughins
dhughins's Avatar
vin is 4C254A104155 when i decoded it on american classic website it said the 25 is for 3/4 ton, 4 is for 1964, a is for atlanta, 104155 is production number
Old 08-26-2008, 07:15 AM   #7
Darinc74
Darinc74's Avatar
I think this frame has been cut down.
"We the willing led by the unknowing, are doing the impossible for the ungrateful. We have done so much for so long with so little, we are now qualified to do anything with nothing."
Darinc74 is offline   Reply With Quote
Old 08-26-2008, 07:37 AM   #8
63sbssbbw
UCA63
63sbssbbw's Avatar
I thought the-c-54a------ stood for longbox
and a 44 would be a shortbox
4=1964
c=single cab pickup
1or2=1/2 or3/4 t or could it be 1/4 or 1/2t
54=lwb,,,,44 for swb
A=assy plant
101010 prod #
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 08-26-2008, 11:35 PM   #9
Captainfab
60-66 Nut
Originally Posted by Darinc74 View Post
Attachment 385836
....looking at the front bed mount also.....a little cobbled looking.
Old 08-27-2008, 06:25 AM   #10
dhughins
dhughins's Avatar
i think ya'll are right. thanks for the help.
Old 08-27-2008, 08:19 PM   #11
dhughins
dhughins's Avatar
ya'll were right here is where the frame was shortened.should i get it boxed in there or scrap the frame all together, or does it look ok?
Old 08-27-2008, 08:25 PM   #12
GMC65Guy
IS there a plate welded in on the inside of the "c" of the frame where the cut is??
GMC65Guy is offline   Reply With Quote
Old 08-27-2008, 08:42 PM   #13
dhughins
dhughins's Avatar
i don't think so i'll have to look again tomorrow
Old 08-27-2008, 10:14 PM   #14
Fred T
Cantankerous Geezer
Fred T's Avatar
I don't like the looks of that weld on the outside. Can you post pics of the inside of the frame weld?
If I were doing the splice, I would make a doubler that nests inside the frame rail. It's more work than boxing the rail, but it doesn't play havoc with the load distribution like a box does.
Fred
Old 08-27-2008, 10:46 PM   #15
protrash64
Resistance is Futile
protrash64's Avatar
Just go ahead and Z it!!!!!!!!!!! I think you're going to have a nice collection of road reflectors.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-28-2008, 08:06 AM   #16
63sbssbbw
UCA63
63sbssbbw's Avatar
I agree ,s/b a step type cut not striaght, looks like po tossed ouy the wrong bed mount,hence the wood blocks.....HMMM
T
member#7816
'61 GMC in progress
