Old 08-26-2008, 09:38 PM   #101
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: Here is a "Not Your Typical" 4wd Blazer build
Originally Posted by sandking View Post
Should be a pig on the low rpm, but good at highway speeds Thanks again for looking out.
Just a thought but you could always throw a 203/205 doubler into the mix, and wind up with a truck that can do the low speed as well. Hell you could run 3.08 gears, then when you stuck it in 4 low on the 205, that would be like having a 5.97 geared rear end... And you would still have a lower gear than that with the doubler...
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 08-26-2008, 10:40 PM   #102
sandking
.....I am working on it.....
sandking's Avatar
Thanks, but I dont have a use for that. This will probably see more higher speeds then anything else. And to top it off, I will rarely use the 4wd.
View my build thread HERE
sandking is offline   Reply With Quote
Old 09-21-2008, 10:44 PM   #103
sandking
sandking's Avatar
Thought I would bring this back. I have not done much the past month or so except for this weekend. Got the front and rear seats mocked up. The driver has a seat slider installed for the wifey ................
Front stuff...
Old 09-21-2008, 10:47 PM   #104
sandking
sandking's Avatar
More front stuff...
Old 09-21-2008, 10:49 PM   #105
sandking
sandking's Avatar
...............and a few of the rear seat..........
Old 09-22-2008, 09:54 PM   #106
hgs_notes
GEARHEAD
hgs_notes's Avatar
Is it normal to mount the seats to the cage? Seems like it would be more comfortable mounted to the cab floor so there is some cushion through the cab mounts. With htem bolted to the cage, and hence the frame, you'd feel every little bump and vibration. Or are there dampeners between the seats and cage?
hgs_notes is offline   Reply With Quote
Old 09-22-2008, 10:16 PM   #107
sandking
sandking's Avatar
I guess that is why the seats are called "Suspension Seats".......... Seriously, In offroad, you dont want anything but your suspension to flex, let alone rely on sheet metal to hold you in place. Even though the stock location is beefed up some, it will not hold up the high speed offroad abuse. By mounting the seats to the chassis/cage/frame, you gain a solid mount that will unlikely fail in the event of a barrel roll. Dont get me wrong, these are not those big comfy captain chairs like in the newer cars, because when you are haulin ass in the desert, you want your ass planted firm in the seat so you cant move. This is a typical mounting type for this type of application.
Old 09-22-2008, 10:26 PM   #108
desertrat
desertrat's Avatar
Man you are doing a nice job! Can't wait to see it done.
Looks like you spend alot of time at desert races
desertrat is offline   Reply With Quote
Old 09-22-2008, 10:28 PM   #109
sandking
sandking's Avatar
Thanks!!
I do, just went to the Score Primm 300. And probably the Laughlin race in January.
Old 09-22-2008, 10:45 PM   #110
desertrat
desertrat's Avatar
Thanks!!
Cool, maybe I will see you at the races.
Old 09-23-2008, 11:24 PM   #111
hgs_notes
GEARHEAD
hgs_notes's Avatar
OK, That makes sense. Obviously not a lot of desert racing going on in my immediate area. Maybe we need a new class of off-road racing, something us midwestern guys could get into besides mudding. How about corn field races, or soy bean field racing. Plowed and un-plowed divisions.
On second thought, that would kinda suck. Mudding and wooded trails it is then.
Old 09-24-2008, 01:45 AM   #112
skchevota
skchevota's Avatar
very nice work! Its moveing along faster than mine.
skchevota is offline   Reply With Quote
Old 09-24-2008, 08:01 AM   #113
drbyrdman
drbyrdman's Avatar
how did you attach the cage to the frame??
drbyrdman is offline   Reply With Quote
Old 09-24-2008, 08:25 AM   #114
sandking
sandking's Avatar
Thanks.
Do you have a build goin on?
Old 09-24-2008, 08:32 AM   #115
sandking
sandking's Avatar
1/8" plate to the frame then the tube to the plate. It's not done yet, but you can see the route I am going here........
Old 10-23-2008, 04:30 PM   #116
manimal
manimal's Avatar
Very nice work. This is the same set up I was gonna do to my '75 C10. Still havent decided if I want front a-arms or convert to 4x4 w/radius arms. But I would like to build a prerunner(of sorts). Great work.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 10-23-2008, 09:58 PM   #117
skchevota
skchevota's Avatar
Thanks.
so I missed this one for the last month....
Yes, I do have a build going on, between the customer vehicals.
Mine is "project Rolling Thunder"
its been a while since I updated it, maby I will dothat tonight.
any update on yours?????
Old 10-23-2008, 10:10 PM   #118
sandking
sandking's Avatar
-Lance
Thanks!! To be honest with you, if you dont really need or want the 4wd, the a-arms are a way better suspension for wide open desert. If this Blazer was purchased as a 2wd, it would have center mounted a-arms without a question.
Old 10-23-2008, 10:14 PM   #119
sandking
sandking's Avatar
Not much done since these last few pics. I might get some things done this weekend. I have new fenderwells and patch panels for the bed area. In the pics, you can see the rusted areas by the rear fenders. Then I need to fab all of the harness mounts and finish the seat stuff.
Old 10-24-2008, 08:56 AM   #120
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Man she is looking good, what bender are you using?
Old 10-24-2008, 11:56 AM   #121
sandking
sandking's Avatar
Thanks!! I built my own "Got Trikes" bender that uses Pro Tools dies.
Old 11-20-2008, 06:31 PM   #122
fun in dirt
fun in dirt's Avatar
I'm bored at work & thought I would check on your build...so how's it going???
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 11-21-2008, 10:57 PM   #123
sandking
sandking's Avatar
It is moving slow. Got the rust cut out of the rear inner fender area and got the new fender wells mocked in place. Thats about it for the next few weeks. I will update when I get more done.
Old 12-10-2008, 01:35 PM   #124
anti bling
epic ride! very nice fabrication. please update when more work is done. I'm very interested.
anti bling is offline   Reply With Quote
Old 12-14-2008, 10:55 AM   #125
NEVERENOUGH
NEVERENOUGH's Avatar
Hey Sandking very nice build. I remember when you were selling your sand truck and starting this. I can't wait to see it a full roller going to be sikk for sure.
NEVERENOUGH is offline   Reply With Quote
