Old 02-21-2001, 07:13 PM   #1
Silverado6.6
Talking It has started.......
Well, first off, I'd like to thank you all for responding to my first post "why isn't my truck starting?!" well, I traced the problem all the way down to the high quality auto zone unit that I had.....it was "new" and had not been on anything, I took it right out of the box, and bolted it up...well, needless to say, i went back to AZ, and got yet another "new" starter and bolted it up and it spun over....I was quite happy....after discovering I had my distributor in 180 degrees off, and swapped over all my spark plug wires...I got it to start up, and ran it for about 6-7 minutes...while adjusting rockers and such, I went back up today to get some more work done on it....and drove it around the lot a little bit, it feels like it'll be kinda peppy, time will tell....anyways, I have one more question, the vacuum line that goes from my tranny (TH400) to the ???? I've got an edelbrock #1406 600 cfm w/ elec choke on top of the stock cast iron manifold....where do I put this vac. line?? does it go to the front of back of the carb, or what? if I can get all these little things taken care of, I should be driving it by friday....thanks again
'81 3/4 ton Silverado Warmed up 355
TH400 w/shift kit
Corporate 14 bolt w/ 3.73s
94 S10
82 K30
81 C20
80 K20
76 C10
69 C20
68 C10 4 sale
51 3600
Silverado6.6 is offline   Reply With Quote
Old 02-22-2001, 02:15 AM   #2
bigd65
bigd65's Avatar
Post
you should have a vacuum port on the manifold behind the carb, that is where it hooks. if not then just hook it to any manifold vacuum sorce. if it is a stock cast iron manifold it should have the port on the manifold or a place you can screw one in. good luck.
85 C10 350/700r4
HOLLEY STREET DOMINATOR IANTAKE
EDELBROCK 1406 COMP. SERIES CARB.
HYPERTECH POWER COIL
FACTORY HEADERS
MAGNAFLOW CAT/MUFFLER/3in. EXHAUST
3.42 REAR GEARS
PROTHANE SUSPENSION-TOTAL KIT
and still going
"thats my toy"
Jeff Dodson
Angleton,Tx.
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 02-22-2001, 02:20 AM   #3
t korinek
Truckin' Krazy
t korinek's Avatar
Post
The line just runs straight to manifold vaccum, usually to the port coming right out of the manifold behind the carb.
Dealer for:
American Auto Wire
Precision weatherstripping
Dakota Digital
Trim parts Carpets
Truck World seat covers
& Many others
Chevy Parts locator in Mesa AZ!
t korinek is offline   Reply With Quote
