Old 08-27-2008, 10:51 PM   #1
mnky30
mnky30's Avatar
got the 3/4 ton front x member install
here are some pics of taking the 1/2 ton torson bar front out and installing the 3/4 ton front x member and the 14 bolt rear that will be put in in a couple of days.thanks to my friends that are helping since i am still not able to do the work cause of neck surgery.
vinnie
1960 chevy c10 frame with a 1966 cab
2002 dodge intrepid r/t
2004 chevy 2500 4 door short bed
mnky30 is offline   Reply With Quote
Old 08-27-2008, 11:03 PM   #2
mnky30
mnky30's Avatar
Re: got the 3/4 ton front x member install
my other question is i have a set of coils from a 84 chevy 1/2 ton that i think will work am i right.thanks for any input
vinnie
Old 08-27-2008, 11:18 PM   #3
64c20crewcab
64c20crewcab's Avatar
Hey Vinny, u got some good friends! your truck build is coming along.
as for the coils, i beleive i used a set of early 80's 1/2 ton lowered coils on my 64 c10 long ago. fit without issue. so for a C-20 3/4 you should be just fine. overall outside diameter of the springs did not change.
please post pics of 14b rearend installwhen ya can. i'm to use a late model 14b rearend in my 64 c20 soon. just need to get it regeared to 3.42 first.
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 08-27-2008, 11:41 PM   #4
mnky30
mnky30's Avatar
hey 64 as soon as i get the origonal pinon angle from me old eaton i will be starting the rear end install it will be just tacked welded for the fact i only have a 110 wire feed welder for now but my freind is going to take it to his shp so i can weld with a much better welder and will post pics soon. my buddys want it to be a roller in a week or two and the motor and trans in place and cab on. got to love your buddys.
vinnie
