Old 02-22-2001, 01:06 PM   #1
69Custom
69Custom's Avatar
Question Truck Overheating ?????
Ok, I now have a problem with my rebuilt engine. It is a rebuilt 350, bored 40 over, 400 small block heads, mild cam, and roller rockers. I put a rebuilt water pump on it and a new thermostat. It started to over heat after having the engine in for about three weeks. I replaced the thermostat with a high performance one (both are 190 degree). I am also using that new antifreeze, 150k mile stuff. I also lost my control of my heater. When I got to work today it was overheating off and on, and at lunch time I didnt have to go far, but it almost stayed at 260 the whole time. I open the hood with the truck running and felt the hoses. The ones going into the firewall were cold, the top hose from the thermostat was really hot and the lower one that goes into the water pump was somewhat hot. Can any one give me a clue to what is happening?
Thanks in advance
Jerr
New Project
  • 72 Blazer 4WD 307/3 spd, PS, PB, Posi (Current Project)
  • 83 Chevy SWB Rebuit 350/TH-350 with shift kit, buckets (daily driver)
1972 Chevy C-10 Short Stepside
6Cyl, 3 spd, not opts
(Current Project)
Now a 2004 SSR 5.3L with 4L60E
Now Ididit tilt- ps, pb
2002 Saturn L200
2006 Toyota Highlander HYBRID
69Custom is offline   Reply With Quote
Old 02-23-2001, 01:47 PM   #2
bigd65
bigd65's Avatar
Post
get you a mechanical to make sure it is over heating. if it is sounds like maybe a circulation problem. mine when it was overheating, i put new water pump, thermo, and a 4 core radiator. but my problem was the fan. i had to put a new clutch fan. good luck just my experience.
85 C10 350/700r4
HOLLEY STREET DOMINATOR IANTAKE
EDELBROCK 1406 COMP. SERIES CARB.
HYPERTECH POWER COIL
FACTORY HEADERS
MAGNAFLOW CAT/MUFFLER/3in. EXHAUST
3.42 REAR GEARS
PROTHANE SUSPENSION-TOTAL KIT
and still going
"thats my toy"
Jeff Dodson
Angleton,Tx.
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 02-26-2001, 02:43 AM   #3
Adam
Post
If you are using the Dexcool (I think it's red) antifreeze, get it out. I've heard countless people say that when that stuff gets overheated, it breaks down and plugs everything up-even on the brand new vehicles that come from the factory with it. Just remember that Dexcool and green antifreeze are not compatible at all-you'll have to flush it many times to get it all out.
'93 1/2-ton Cheyenne 2wd
408" smallblock with vortec heads, 9.2:1 CR, Performer Intake, 454 TBI, Comp Cams XE268H cam, custom chip, Thorley headers/true dual exhaust. 375-400 HP. 4L60E w/ Trans-go kit.
408" smallblock with vortec heads, 9.2:1 CR, Performer Intake, 454 TBI, Comp Cams XE268H cam, custom chip, Thorley headers/true dual exhaust. 4L60E w/ Trans-go kit.
Adam is offline   Reply With Quote
Old 02-26-2001, 06:11 PM   #4
69Custom
69Custom's Avatar
Post
Thanks Adam, I think that us what I am going to do.
Jerr
New Project
(Current Project)
2002 Saturn L200
