Old 08-28-2008, 04:55 PM   #1
dhughins
dhughins's Avatar
brakes ? again
i'm beating the dead horse.
could some one make me a list of what i would need to swap to disc on the front.
1. will 86 A arms and components work?
2. upper arms
3. lower arms
4. spindles
5. rotors
6. calipers
7. inner tie rod ends
8. outer tie rod ends
9. master cylinder w/ power booster
10. brake lines.
did i forget anything?
idler arms pitman what else is down there?
i need an exploded view of the components
dhughins is offline   Reply With Quote
Old 08-28-2008, 08:19 PM   #2
83burban
Re: brakes ? again
1) Prop Valve
2) Tie-Rod end adapters (to match inners with outers from different years)
83burban is offline   Reply With Quote
Old 08-28-2008, 08:43 PM   #3
dhughins
dhughins's Avatar
Re: brakes ? again
where do you get tie rod end adapters?
