Old 08-30-2008, 01:46 PM   #1
frostie_122
anyone using aftermarket heater ac systems?
i've got the factory ac in my truck(comp. is bad). im looking into putting in an aftermarket heat/ ac system that will replace the monstrocity onder the dash and under the hood...the big plastic bullsh*t box's.
ive seen kits that will work with factory vents and will tuck under the dash or are small enough and clean looking to go under the hood...
any ideas?
frostie_122 is offline   Reply With Quote
Old 08-30-2008, 06:42 PM   #2
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: anyone using aftermarket heater ac systems?
Had some thoughts about updating my 'open the windows' AC.
One issue tho, its BIG!!!
Actually just salvaging the electric motor but it did look kinda funny!
Born with a Bowtie
1971 C/10 350/350 Daily Driver/project
Assumption=The mother of all -ups
Highsteel is offline   Reply With Quote
Old 08-31-2008, 08:48 AM   #3
Senator350
Senator350's Avatar
I'm not sure about AC, but I'm installing a Flex A Lite Mojave heater. The resulting clean firewall was just amazing! Who knew that there were 1950's fallout shelter signs behind all that massive AC/Heater core!!
RN U OVR
Senator350 is offline   Reply With Quote
Old 08-31-2008, 07:32 PM   #4
awhite4557
awhite4557's Avatar
I just put a Vintage Air system in my 71, works great. It wasn't too bad to install. The firewall is clean and the underdash is the same but I lost most of my glove box. The link below has the picks.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 08-31-2008, 08:42 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I'm having to replace my cowl, and the replacement is from an air cab. So, all my a/c stuff will transpose into the new metal.
What I don't like is the huge compressor, so I'm thinking a Sanden compressor will do the job and be R-134a compliant. Other minor changes to the system to enable it all to work in harmony is my goal. Same controls and outlets with a smaller compressor.
But keep the the ideas coming. I just can't afford an aftermarket A/C system for now.
Member Nr. 2770
Old 09-01-2008, 05:52 PM   #6
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Redneck AC, & of course, it's a f*rd...............
68shortstep is offline   Reply With Quote
Old 09-04-2008, 12:52 AM   #7
frostie_122
...but really any one else?
Old 09-04-2008, 05:57 AM   #8
wHATANERD
wHATANERD's Avatar
I like the look of the Vintage Air setup also. It's alot smaller than the factory unit, and gives a very clean firewall. The only drawback is less glovebox space.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
