Straight jacket required
Copper fuel lines?
Has anyone used copper fuel lines, or is there a problem with disimiliar metals??
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
Re: Copper fuel lines?
I don't know if it's a good idea, it'd be easier to bend for sure, but I don't know if it might cause you problems if it reacts badly to gas, I'd stick with steel lines myself, someone else will chime in more knowledgeable than me. Why would you want copper feul lines anyway?
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
Cuz I'm a plumber and like you said, it's easy to bend.
I came across 2 wrecked trucks the other day with copper lines. The 1st 1 had two saddle tanks and 1 behind the seat tank and they were all connected by copper lines, the other just had a copper line running from the sending unit to the bottom of the cab, then rubber. Not sure how the gas reacted to the copper though. Just thought it was interesting.
1969 4x4 Nothing beats a good rock drill and some dynamite |
Yeah, I'd like to find out how it reacts to it first.
Firefighter
I've seen them used and they seem to hold up ok, but I would still go with steel or stainless steel if it were me!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
laying low
![]() Join Date: Mar 2001
For safety reasons. In the event of an accident the copper tubing would colapse and split sooner than standard fuel tubing.
Hollister Road Co.
Copper is prone to vibration fractures so its not used on gasoline lines. Nickle-copper is ok.
dwcsr is correct ... copper will "work harden" and eventually crack due to constant vibration ... think of taking a piece of coat hanger or bailing wire and bending it back and forth and it will eventually fracture at the bend point.
lots of guys have used copper in the past, but I'm not sure I would take the chance when much better alternatives are available ... especially considering how flammable gasoline is. |
![]() Join Date: Mar 2003
Would never use them personally b'cuz of the already mentioned potential problems----------however, I do see them quite frequently on these trucks with the added on side tanks, along with the plastic lines.
![]() Join Date: Aug 2008
Copper`s sure enough easy to bend.But,that`s the problem.It`ll keep on bending.Whenever you work around it you`ll end up bending it when you didn`t want to.Te steel has a rigid quality,bends nicely with proper tools,and stays that way.
That's good enough for me, thanks everyone for your inputs. I'm going to go with stainless from Inline Tube. Thanks again.
Licensed to Thrill!
I used copper from my filter to the carb. Reason being my inlet on my Edelbrock was just going to be hard to hit and make it look right without the fitting I needed, so, I used copper because it was easy to bend. BUT - I also put rubber fuel line over the copper just in case.
![]() DLB Last edited by Orange; 09-04-2008 at 11:04 AM. |
#15 |
its all about the +6 inches
when I got the longhorn, it had copper lines on it... ftom the tank to the pump. It looked like it had been there for many years and was still in good shape.
However, I agree with the above... not a good idea. |
#16 |
I found that alot of folks use copper to fix rusted fuel lines up in the north east. Never saw one cause a problem but I never had one with copper for a long time.
Tim |
#17 |
I'd say the only problem would be potential breakage during an accident. Which is the same potential problem for steel lines. Gasoline is petroleum based, as is LP (propane or butane), and those systems are hooked up with soft copper lines. So as far as any chemical reactions over the years, I'd say that's not going to pose any long term problems.
#18 |
English Chevy Owner
I have copper fuel lines on my truck (OK its Kunifer, copper Nickel) with no problems and have had many cars over the years with copper. In our wet climate thars far less chance of a leak through copper fracturing than there is through a steel line rusting!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
#19 |
Active Member
![]() Join Date: Jul 2007
20 years ago, I used copper tubing on my 69 Chevy when I converted it to a 350. (I couldn't find a replacement.) It's still there and never had any problems.
Truck is parked now and when I redo the engine I will get the metal one since it's easily available and looks better. But, in a pinch, I wouldn't hesitate to do it again. |
#20 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I am not advicating copper, but for a show truck.... Pollished copper would look cool!! WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#21 |
SOLD
Location: Poorest state in America(Breaux Bridge,Louisiana)
copper is used on custom old school choppers for the look, i don't think i would use it on a classic truck though. I would use just a piece like ORANGE did though.
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 |
#22 |
WTB this ad
It does look cool though doesn't it?
#23 |
![]() Join Date: Feb 2002
I've had a copper 3/8 fuel feed line from the fuel pump to the carb on my 292 for 31 years. No problems.
#24 |
What are these made out of?
![]() They sure look like copper under the chrome when you cut one up... |
#25 |
Damn Yankee
I think most cars and trucks in the 30's and 40's used copper fuel lines
