Old 09-04-2008, 10:00 PM   #26
bwilder10h
Re: Options for cleaning up frame with body on?
Originally Posted by MylilBowTie View Post
I have a pressure washer and engine hoist
Are you offering your services or tools
bwilder10h is offline   Reply With Quote
Old 09-04-2008, 10:45 PM   #27
COMP
Originally Posted by N2TRUX View Post
Tin foil works great when you are detailing an area that you don't want to or can't remove everything out of the way. Wrap it with a few layers of tinfoil and scrunch it tight against the part that doesn't get painted.
you get a fine line that way ??
COMP is offline   Reply With Quote
Old 09-04-2008, 11:04 PM   #28
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I can bring my hoist / pressure washer and help out if you need help.
I would get some super clean and some plastic bristle brush's to help loosen the grease/dirt. Then pressure wash that off.
Depending on how the bed bolts act. It may be a good idea to cut them off so it doesn't ruin the bed floor. I have a sawzall need to pick up some new blades.
MylilBowTie is offline   Reply With Quote
Old 09-05-2008, 12:34 AM   #29
Eyegore
What Hump?
Eyegore's Avatar
If you want to strip it of grease and grime I have heard that some have used oven cleaner, spray it on let it foam up and use a scraper to clean off the major grime and rinse off.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 09-05-2008, 01:59 AM   #30
Fer79
Fer79's Avatar
kbs coating http://www.kbs-coatings.com/KBS-All-...it_p_8-36.html
Fer79 is offline   Reply With Quote
Old 09-05-2008, 08:30 AM   #31
bwilder10h
That's very generous of you.
