Old 09-08-2008, 11:48 PM   #1
tk-mpl
tk-mpl's Avatar
CPP trailing arm crossmember??
I am trying to put in a rear trailing arm crossmember in my 68 C10. It is a dropped CPP one. I have found out that the previous owner cut a long box frame into a short box and then moved and welded in the stock crossmember. Without thinking I did not mark the position of the stock one before I cut it out. Is there anything that I could reference from the front of the frame and measure up to put the crossmember in the right place.
Anybody got pictures and measurements.
Thanx.
tk-mpl is offline   Reply With Quote
Old 09-09-2008, 01:28 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: CPP trailing arm crossmember??
Thanx.
How about mocking up the trailing arm crossmember with the arms and axle attached so you can center the wheels right where you want them? It will probably be more work, but you can get the centerline right where you want it.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-09-2008, 11:43 AM   #3
tk-mpl
tk-mpl's Avatar
I was thinking about that, but at this point I am unsure of what the ride height is going to be. I have the front all apart too. I was curious as to what people are putting in for front and rear air bags and what height the bags should be at actual ride height.
Thanx
Trevor
Old 09-09-2008, 07:41 PM   #4
cheford
I measured my frame from the straight endge of the crossmember above the rear springs to the back edge of the cross member the trailing arms attach to and get 40 inches, don't have any pictures at the moment, hope this is of help. I have a 72 frame.
John
cheford is offline   Reply With Quote
Old 09-09-2008, 10:19 PM   #5
tk-mpl
tk-mpl's Avatar
Thanx John I will measure that up and see where I am at.. Do you have the CPP crossmember aswell??
Trevor.
Old 09-10-2008, 06:28 PM   #6
cheford
Trevor.
No , i have the original cross member and I'm waiting on the arrival of my new trailing arms from early classic. Just finnished painting the frame and I'm now starting to assemble it. I had bought the grand slam package from CPP and am hoping that there will be no problems with the parts as most are made in China and not North American made as I thought, but it's going to be some time before I find out, I have a long ways to go.
Old 09-15-2008, 02:33 PM   #7
hotrodsbyray
mind if i ask a question?
any way you could measure that cross member for me?
width and height at the ends where it bolts to the frame?
i am considering trying to convert my 57 to the trailing arm suspension using CPP parts but am actually having trouble getting somebody to get some measurements - and i know it sounds weird but i have yet to find one at a local show i could get under to measure.
thanks
hotrodsbyray is offline   Reply With Quote
Old 09-15-2008, 03:37 PM   #8
tk-mpl
tk-mpl's Avatar
I can meassure it and post the meassurments for ya.
Old 09-15-2008, 06:25 PM   #9
cheford
The original cross member is 33- 1/4 wide by 5-13/16 high by 4-3/4, the CPP or Early Classic Enterprise cross member would be of the same dimension other than the thickness of material and the location of the center hole for the drive shaft and provision for exhaust pipes. If your thinking of using it on a 57 you would likely save yourself money picking one up at a wrecking yard. Your running board brackets hang about 6 inches lower than the frame, much the same as my 56 Ford so there is no real advantage of the after market cross member other than time spent finding and removing one from on old frame.Hope this is of help.
John
P.S. if you do decide to buy after market, purchase everything from the same vendor so that everything fits, modifying new parts is a pain and hard on the nerves.
Old 09-16-2008, 10:28 AM   #10
hotrodsbyray
thanks a bunch for the help guys!
well, i am off to the local salvage yard!
