09-10-2008, 10:32 PM | #1 |
Fuel tank selector valve leaking!!!!!
I have an 86 GMC short bed two wheel drive truck with dual fuel tanks. My problem is the selector valve that allow you to switch from one tank to another has a crack in it and its spilling gas everywhere. I went to Napa Autoparts and at a Chevy dealer with no luck, also loooked on LMC, and Brothers with no luck. Does anyone know where i can get another one? Any help would be greatly appreciate, thanks Michael from Arizona.
09-10-2008, 10:40 PM | #2 |
www.73-87chevytrucks.com
Re: Fuel tank selector valve leaking!!!!!
I have bought them at Autozone, NAPA, GM and Advanced Auto.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-10-2008, 10:42 PM | #3 |
Robert Olson Transport
advanced auto has themonline heres for an 82 but they have em all
http://www.partsamerica.com/ProductL...pe=831&PTSet=A
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
09-10-2008, 10:51 PM | #4 |
Bought mine at the local dealer dont know if it was cheap or not but in that moment i thought i needed it, but no i did not it was only the fuel filter..
09-10-2008, 11:31 PM | #5 |
BAD BOW-Silverado XST
Find an A/C Delco store.
09-11-2008, 02:01 AM | #6 |
In the Forgotten far North.
I found the listing for the selector valve on NAPA's websight. Had to do some digging but I finally found it.
Fuel Tank Selector Valve Part: CRB 22198 Product Line: Echlin Fuel System Price : 124.00
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 09-11-2008 at 02:02 AM. |
09-11-2008, 11:40 PM | #7 |
Junior Member
Thats the same one i used on my 87 bolts right on
67 short bed fleetside/1997 c1500 exteded cab/ 2004 accord/87 c10silverado 350 od tbi |
09-12-2008, 12:08 PM | #8 |
Windy Corner of a Dirty Street
The GM and AC Delco part number is 14029228. I just bought one a few months ago for some where around $100 if I recall. It is the same Pollak valve that you find at Napa or anywhere else. Someone has to have one at a decent price. A GM stealer will probably put the screws to you for it though.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
09-12-2008, 02:13 PM | #9 |
Does anyone know the pressure rating on these fuel tank selectors? I'm planning to put a TPI setup in my truck at some point. I'd like to run my pumps in the tanks but that would require the fuel tank selector to handle the pressure.
09-12-2008, 02:40 PM | #10 |
Yes, it is 65 PSI max pressure for that valve. You can find the spec sheet on that valve on Pollaks website.
Funny you should ask that question as I just put a 8.1L in my truck and had to bypass the valve as the return line that runs through the valve back to the tank is too restrictive and caused the fuel pressure to run around 100 PSI, which is way too high. I decided to run a Corvette in-tank pump on the RH side as well as an aftermarket center mounted high volume low pressure pump to transfer fuel from the LH to the RH tank and do away with this valve all together. The Pollak switch valve discussed above was not designed for high fuel pressure systems. TBI only ran around 12 PSI with the return pressure no more than a dribble. The MPI on my Marine controlled 8.1L and your TPI require around 38 to 43 PSI with a clean restrictive free return line back to the tank. I am sure you will find this valve too restrictive on the return side as well which will cause fuel pressure issues at the engine.
08-15-2017, 10:17 AM | #11 | |
Posted via Mobile Device |
08-15-2017, 05:39 PM | #12 |
The 5/16" line is for vapor and the 1/4" is for fuel return.
08-15-2017, 06:00 PM | #13 |
08-15-2017, 09:14 PM | #14 |
08-15-2017, 09:33 PM | #15 |
Just bought one last week at a napa in so cal 92.00
