Old 09-11-2008, 10:29 PM   #201
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: 67 C-30 Dually pickup build.
Cool
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 09-18-2008, 03:25 PM   #202
djw32
I have a question:
If you use the 69 big block motor mounts, will the rest of the running gear(trans(automatic) and drive shaft) stay in the stock location?
djw32 is offline   Reply With Quote
Old 09-18-2008, 06:02 PM   #203
67_C-30
I have a radical idea!
67_C-30's Avatar
Originally Posted by djw32 View Post
I have a question:
If it is already a V8 truck, yes. If it is a cylinder truck (like mine was) the tranny crossmember will have to come forward and the front driveshaft would have to be from a V8 truck. The big block frame mounts bolt in the same location as the SBC mounts, but sit the engine about an inch or so higher.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 09-19-2008, 11:33 AM   #204
djw32
[QUOTE=67_C-30;2895674]If it is a cylinder truck (like mine was) the tranny crossmember will have to come forward and the front driveshaft would have to be from a V8 truck. QUOTE]
What does that mean?
Old 09-19-2008, 04:24 PM   #205
I think he meant 6-cylinder truck. They have the tranny/clutch housing mounts back further that the V8 trucks do.
Old 09-19-2008, 07:38 PM   #206
67_C-30
67_C-30's Avatar
Duh! Sorry about that! Palf70step is right, I meant 6 cylinder truck!
My trucks
Old 09-21-2008, 11:00 PM   #207
djw32
Is the motor sitting in its final resting spot? If it is, did the front end sag at all from the additional weight from the diesel to the 6 cylinder? When I had the 6.2L in place of the chevy 350, the front drop about 1.5-2.5 inches... What springs do you plan on running?
thanks, David
Old 09-22-2008, 09:20 AM   #208
72freak
Rottenwood Garage Member
72freak's Avatar
I raised the front of mine with some 3" lift springs, and I am running some taller tires on the front. I went from a 9" "red neck" rake to about 4" of rake rear to front. If I keep it she will get a 4TB.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 09-22-2008, 09:33 PM   #209
67_C-30
67_C-30's Avatar
thanks, David
Yes, I mounted it permanently yesterday. It did drop a little, but I'm going to change the front springs to level it out like 72Freak did on his. The BBC mounts worked out great, and it has plenty of clearance everywhere. Here's a few pics of it installed.
My trucks
Old 09-22-2008, 09:54 PM   #210
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Good job man! Cant wait to hear it run!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-23-2008, 01:55 PM   #211
djw32
Look at that! Good job. This is a 6.2 with the turbo parts from a 6.5L, right? Keep up the good work.
Old 09-23-2008, 04:28 PM   #212
67_C-30
67_C-30's Avatar
Yes, it is '86 J code 6.2L from a military CUCV with '93 6.5TD parts on it.
My trucks
Old 09-24-2008, 01:49 PM   #213
djw32
Are you going to run the 86 drive assy, or are you going to upgrade to the 89 serpentine system? Thanks for the pics.
David
Old 09-24-2008, 09:04 PM   #214
67_C-30
67_C-30's Avatar
David
For time being I'm going to run the V belts just for the fan and alternator. The military set-up is different that civilian, and I'm going to run dual belts on the alternator. I have a serpentine set-up from a '97 6.5TD that I'm going to put on it when I put on the A/C and the hydroboost setup.
My trucks
Old 09-26-2008, 08:10 PM   #215
67_C-30
67_C-30's Avatar
I started building my exhaust this evening. I am going to run a 4" mandrel bent custom system from the turbo back with the Warpspeed straight- through design muffler. The factory exhaust housing on the rear of the turbo is restrictive and causes a lot of back pressure on these GM-X series turbos. The inside of the casting measures a touch under 2.600" at the outlet and is more restricted than the where the 90 degree bend is. I decided to build a custom system that will be 4" from the turbine housing back. I machined the flange at work on the CNC, and I'm building the pipe from pre-bent 90 and 45 degree pipes that I will have to cut and butt-weld to the straight lengths. I am going to run outside of the frame rail due the position of the turbo and the narrower frame on these year trucks vs the newer ones that the 6.5TD were designed for. I'm planning on turning it out right before the rear wheels on the passenger side. Here's a few mock-up shots.
My trucks
Old 09-26-2008, 09:06 PM   #216
thirdstreettito
Resident of Here
Good work! But no stacks?!?!
~Bradley~
Miss having a truck
Old 09-27-2008, 01:58 AM   #217
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Where in Alabama do you live ???
I think I need a vacation & would love to come work on your truck
We have to do some black smoke pics
Sinister
Killer
Old 09-27-2008, 07:16 PM   #218
djw32
Looks good.
Old 10-06-2008, 06:30 PM   #219
djw32
Any updates?
Old 10-06-2008, 07:05 PM   #220
67_C-30
67_C-30's Avatar
Yes, I was actually about to post this. I finished up the down pipe today. I FINALLY got the pipe fitted and welded top the flange. It took quite a bit of persuasion to make it fit all the way around due to odd shape of rear exit of the turbo. The opening is bigger than the factory opening so there is no overhang. The ended up being a little over 4.5" at it widest point and around 3.5" at its smallest. It is still WAY bigger than the inside of the cast. The last shot shows how wide open the exit is. It makes a nice smooth transistion down for a 90 degree turn. The rest of the exhaust should be pretty straight forward.
My trucks
Old 10-16-2008, 04:33 PM   #221
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
nice
LOW DOUGH is offline   Reply With Quote
Old 10-16-2008, 05:06 PM   #222
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweet
Sinister
Killer
Old 10-16-2008, 06:49 PM   #223
thirdstreettito
Resident of Here
Schaweet!
~Bradley~
Miss having a truck
Old 10-21-2008, 11:31 AM   #224
djw32
I was looking over the pics again...this is one clean build. Whats new in the south? any updates?
Old 11-19-2008, 08:43 PM   #225
thirdstreettito
Resident of Here
Updates?
~Bradley~
Miss having a truck
