#301 |
Just like to part out trucks!!
Re: you want parts!!!!!
Mt man chad, sorry its been sold
swb72, sorry none right now Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
#302 |
I need the small small piece that bolts to the bottom front of the front door pillar and the cab support. It has the large hole for the lower rear of the fender to bolt to.
thanks, Dave
72 LWB fleet 402 with a/c 68 SWB fleet 327 (frame-off in progress) 03 GMC 1500 collector of 1/18 diecast cars (not NASCAR) Franksville WI (15 mi. South of Milwaukee) |
#303 |
DJH, sorry I don't have any trucks here right now to take that piece off for you
Cooldudecoco, I do have a set of those mirror arms, the upper arm that goes to the mirror head has some rust on them. $25 shipped, I can get a pic if interested Thanks Randy
#304 |
Middle-aged Curmudgeon
Randy, I need a track bar (panhard rod) for a 3/4 ton. Might you have one?
Thanks in advance.... |
#305 |
Resident Curmudgeon
![]() Join Date: Dec 1999
Looking for a throttle cable bracket from a 71 or 72 307 V8 (2bbl intake). The one circled in the pic is for a 4bbl intake, I need the similar piece from a 2bbl intake.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#306 |
![]() Join Date: Sep 2007
pm sent, Man you`ve been busy!!
1967custom |
#307 |
![]() Join Date: Aug 2008
I'm lookin for right rear inside and outside bumper brackets(sport)
left side inner bracket for the same. SS Tripod mirror with 12" long arms(glass does not have to be good) AM radio. thanks
Nothing better than an old truck... 76 C-10 Silverado 92 Silverado Z71 |
#308 |
Randy: I'm interested in the Non Air heater control
Please advise price and if still available; Thanks N8wgc@hotmail.com |
#309 |
![]() Join Date: Feb 2005
I need a complete auto shift linkage setup from the column to the trans with the frame bracket(350/350 4x4). Also need a decent set of sunvisors(color does not matter) and a pair of wiper blade holders. Thanks in advance,Randy.
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 |
#310 |
interested in sway bar. and possibly rams horns. how much to 54603?
#311 |
new to board pm me
#312 |
drmiller, sorry no sport bumper brackets or radio. I may have a mirror, I'll have to look
n8wgc, sorry sold all my good ones zuesflash, sorry no 4x4 linkages. I have a bunch of sunvisors $10 a pair, and also original wiper blade arms for $10 plus shipping lax54650, I still have a sway bar, one frame mount has a twist in it but it can be straightened, needs new rubber bushings like most do. $35 plus shipping. I have a set of rams horns for $40 plus shipping Thanks Randy
#313 |
Hi Randy. I will take a pair of sunvisors and if you have two pairs of wiper blade arms(4 total) I will take them also. Let me know total with shipping and how you would like to be paid. Figure shipping to 83854.
Thanks, Mike
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 Last edited by zeusflash; 10-07-2008 at 09:42 PM. Reason: Forgot zip |
#314 |
Don't see a picture but maybe..... I'm looking for the e-brake cable brackets the bolt to the frame a little ways ahead of the rear axle. It's a 72 GMC 3/4T 4x4.
TIA. |
#315 |
Zeusflash, Mike, I pm'd you total
hdflstf, sorry none right now Thanks Randy
#316 |
hey,
looks like you have been busy with parts. I am looking for a brake pedal assembly. any chance you might have one ? 72 auto thanks, Jeff |
#317 |
![]() Join Date: Dec 2007
#318 |
#319 |
#320 |
Rockedawg, I got your sent out Friday, Thanks
Pete29, I only have 2 female ends and belts and only the plastic ends of the males in black, no sets. Hdflstf, I'll watch for you Thanks Randy
#321 |
Engine n00b
Got a Front sway bar for a 70 C10?
#322 |
Chris, I have a complete setup with frame mounts, it will need new rubber bushings adn one of the frame mounts is bent a little bit but would straighten pretty easily. $35 plus shipping. Thanks Randy
#323 | |
Engine n00b
Also - point me in the direction of what I need for rubber if you have a moment? Know someone that sells a kit just for that? |
#324 |
Hi Randy,
Do you by any chance have one of the jumper wires that connects the dual Hi-Lo horns together? It's about 25-1/2" overall length and is green. Thanks for your reply. Monty |
#325 |
what do you want for an air cleaner spacer. the ring between the air cleaner and the carb with the hose that goes into the valve cover. would actually like one without the hose but will take either.
thanks
jim gallagher |
