Old 09-13-2008, 12:40 PM   #1
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
How do you know?
What are the symptoms for a harmonic balancer going bad? I have a vibration in my truck,that you can feel while in park and in drive.I just broke the 2nd carrier bearing in a years time. All new universal joints,drive shaft balanced both times. What do you all think?
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 09-13-2008, 12:55 PM   #2
fine69
fine69's Avatar
Re: How do you know?
I think you might have a bad tranny mount.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 09-13-2008, 01:28 PM   #3
463
463's Avatar
"broke the 2nd carrier bearing " sounds like a rearend pinion angle that out out line. this happens with a ride hight altered. vibration may be from a motor/trans mount . a clutch or torque-converter, fly wheel (ring gear) that are out of ballance. the harmonic balancer is an allmost non fail part, to check look at the front of it and the rubber looks good ( not missing peices) it is in all likely hood still good. the exhaust system touching the body can give off vibration. i like to take a good light and inspect the underside when it's on a hoist for problems.
Trueman
463 is offline   Reply With Quote
