Old 09-14-2008, 08:47 PM   #1
litebulblsc
litebulblsc's Avatar
lifted and needs driveshafts
I got a 6'' lift kit off my brothers 72 k10. Got it on without any problems, but now the driveshafts dont reach. The truck it came off of had stock driveshafts so I assumed I could use the Blazers stock driveshafts. For the front will a k10 driveshaft fit, you think? What about the rear? Any ideas are welcome and appreciated.
litebulblsc is offline   Reply With Quote
Old 09-14-2008, 09:08 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: lifted and needs driveshafts
From West TN
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-14-2008, 09:42 PM   #3
1972CST
1972CST's Avatar
Welcome from NC !!!!!!
Sorry I cant help w/ your problem but this is the best place to ask.
1972CST is offline   Reply With Quote
Old 09-14-2008, 10:48 PM   #4
litebulblsc
Ya, I was hoping this is a good place to ask. Just need some people with experience lifting these to chime in. Also thanks for the welcomes.
Old 09-14-2008, 11:34 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Welcome to the board. Where's LSC? Post some pictures of your rig when you get a chance.
4" lifts are usually safe with the stock and 8" lifts all require drivelines, 6" lifts are the gray area where some require longer drivelines, others don't.
Sounds like you'll need to get them lengthened. Find a driveline shop and give them the new measurements. I've heard it should only cost around $100.
If you become a subscribing member, you could post a "wanted to buy" and possibly find some drivelines from a board member.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-15-2008, 05:39 AM   #6
vtblazer
vtblazer's Avatar
It's time to stop guessing.
Take the measurements and either find a set or have some lengthened to the correct dimension's.
Use a good drive-line shop that will balance the shafts as part of the process.
I paid $60.00 per for a stock set to be stretched.
vtblazer is offline   Reply With Quote
Old 09-15-2008, 09:33 AM   #7
litebulblsc
Well the main problem is that I am a college student with no job. That creates a real small budget for this truck. I should have a front driveshaft that will fit, it will just need new universals. But what I really want to know is if there was a stock shaft on something else that will fit?
Heres how she sat for 9 years after my dad blew the engine and started t as yet another project.
Now this is how she looks.
Not to different, but I only got about 2 months of work in on this and have spent less then $200 not including the price of the truck, rollbar and rims.
location fixxed
Old 09-16-2008, 10:44 AM   #8
litebulblsc
Well i ws thinking about it last night. I got a truck front driveshaft that should fit. Then with the old front and old rear I could comibe them to have a long enough rear. Since the front has the double universal thing and the rear doesnt.
Old 09-16-2008, 04:38 PM   #9
Jtrux
I'm a poor spectator
Jtrux's Avatar
Just an FYI, a K10 front DS will be the same as your blazer DS, the rear will be different though.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-17-2008, 12:20 AM   #10
Critter
Future TOTM Winner
Critter's Avatar
Here is what I did for my front.
http://67-72chevytrucks.com/vboard/s...d.php?t=289285
To be honest I haven't had a chance to really test it in 4x4 situations, but it bolts up fine and has a decent amount of room to extend.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 09-17-2008, 10:54 AM   #11
litebulblsc
What did the shaft come off of with the longer lower portion?
Turns out the k10 front ds was longer, but not long enough.
Old 09-17-2008, 11:56 AM   #12
Critter
Future TOTM Winner
Critter's Avatar
This was a front and rear set from a 71-72 blazer with a th350/NP205 combo. I took the slip end from the rear drive shaft and put it on the front drive shaft. Added about 1.5 inches.
Old 09-17-2008, 12:31 PM   #13
litebulblsc
My blazer is a 72 with th350/np205 and my front and rear slip ends are the same length. With what lookd like a stock 2'' block all around the shafts were basically maxxed out.
Old 09-18-2008, 09:52 PM   #14
litebulblsc
well i got to drive it around in my backyard with ne brakes and just front wheel drive.
