Old 09-16-2008, 12:34 PM   #1
Farnuckel
Farnuckel
Farnuckel's Avatar
Transmission Identification!
I've got a 57 Chevy 3600 with a 235 I6 from a newer vehicle, and a transmission i'm not convinced is original.
It's a 4-speed, with the ratcheting squeeze-brake on the output. On the top of the driver's side, it says GM2 591568. On the passenger side, it says J1955.
I'd like to get a gasket set for this, and I need some parts for the shift handle where it enters the transmission, or a new shift handle. I can't seem to find enough information to know what to get.
Please Help!
Farnuckel is offline   Reply With Quote
Old 09-17-2008, 06:46 PM   #2
OrrieG
OrrieG's Avatar
Re: Transmission Identification!
The part number you have is for the shift housing, the main case should have another number. The date code is September (J) 19th, 55 or 65, usually there are only three numbers. That tranny was the main stay 4 speed from 47 to early 70's. Early models had 4.6" input bearing retained, later 5.125" retainers. I think the input shafts were different sizes too. I thing the shifters are all the same. Let me quess that the tabs on the cone that hold the shifter in place are broken?? Common problem. You can still probably go to the Chevy dealer and get the gasket set since it is so common. They will take a lot of abuse, I had one in my 59 that was growling when I put it in and growled for 10 years, about 40K miles but never broke.
Old 09-25-2008, 01:46 PM   #3
Farnuckel
Farnuckel
Farnuckel's Avatar
Thanks for getting back to me. What broke is the cylinder that houses the metal tab that moves the gears. The roll pin is WAY worn out too. it's functional, but VERY sloppy, and i fear may brake more. I ended up making the gaskets from a gasket material I had. Hopefully they hold up. Would I put 80/90 Gear Lube in there? or ATF? I was guessing gear lube.
Old 09-25-2008, 03:42 PM   #4
solidaxel
solidaxel's Avatar
80-90W should remove the heat,
You could use RTV for gaskets in a pinch if you let it set up a bit, works good on the rear end cover also!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-25-2008, 04:08 PM   #5
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i think those are the sm420 but i may be wrong
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 09-30-2008, 01:07 PM   #6
Farnuckel
Farnuckel
Farnuckel's Avatar
Looks like it could be a Muncie SM420, from what i'm finding on the internet. Thanks!
Old 09-30-2008, 02:59 PM   #7
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Here's a pic of several
sneakysnake is offline   Reply With Quote
identification, tranny, transmission
