Old 09-17-2008, 02:35 PM   #1
spudz
spudz's Avatar
Pic of carb linkage with edelbrock 1405
I am installing a edelbrock 600cfm 1405 manual choke carb that came off of my elcamino.. I want nice brackets and linkage and not cobbled together crap that I usually come up with. Any help would be apreciated...thanks!!!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 09-17-2008, 03:49 PM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: Pic of carb linkage with edelbrock 1405
I just bent my factory rod to fit, drilled a hole in it and used a cotter pin
http://www.67-72chevytrucks.com/vboa...d.php?t=239495
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 09-17-2008, 03:50 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
I feel your pain.
http://www.jegs.com/p/JEGS/752613/10002/-1
I bought the polished version with the return springs and I'm very happy with it. I also purchased the kickdown bracket add on, which worked very well too.
I'll try to get pics of it on the motor.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 09-17-2008, 03:58 PM   #4
spudz
spudz's Avatar
Nice instal, but I dont have a rod...has a cable.
Old 09-17-2008, 03:59 PM   #5
spudz
spudz's Avatar
Originally Posted by Pyrotechnic View Post
I feel your pain.
Cool, man.. So my factory cable just snaps into that bracket???
Old 09-17-2008, 05:52 PM   #6
oldgmc
oldgmc's Avatar
No photos but here is a link to the manual if you need it
http://www.edelbrock.com/automotive_...ers_manual.pdf
oldgmc is offline   Reply With Quote
Old 09-17-2008, 08:06 PM   #7
Pyrotechnic
Here it is
Old 09-17-2008, 09:52 PM   #8
vern350
like a rock
vern350's Avatar
I have the same bracket as Pyrotechnic, except not polished. Kicking myself for not getting polished. Bracket works great. Throttle cable snaps in, and you can buy a kickdown bracket that bolts to bottom size of the throttle cable bracket.
vern350 is offline   Reply With Quote
Old 09-18-2008, 09:40 AM   #9
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
the kickdown brakeet works well i have a holley in my truck and i think thats whats keeping my truck from being any faster it tends to shift the truck too soon and i have no more adjustment in the kickdown. do you guys have pics of the kickdown bracket and the part numbers from jegs.
staggerd86c-10 is offline   Reply With Quote
Old 09-18-2008, 11:02 AM   #10
Pyrotechnic
Just a special note, if you ordered the kickdown bracket add on, it is meant to utilize the same screw as the throttle cable mount. This really limits your adjustment of the kickdown since if they share the same screw, they can only go so far apart.
In my case, the kickdown wanted to be much further back then the throttle bracket, further than using the same screw for both would allow. The good thing here is the slot where the cable mounts ride is very long, so I was able to take a stainless button head allen bolt and a nut, then mount the kickdown mount further back on the slot where I needed it to be. Your situation maybe be different, but that's how it worked out for me with all stock cables.
If you look closely at my picture, you can see how much further the kickdown mount is compared to the throttle mount.
Old 09-18-2008, 04:58 PM   #11
vern350
like a rock
vern350's Avatar
Jegs #555-15229
Old 09-18-2008, 09:50 PM   #12
spudz
spudz's Avatar
thanks everybody.. does it matter that I am using a 400th??? or is it the same kickdown bracket... the only listing I seen was for 350th and 700r4s...
Old 09-19-2008, 10:01 AM   #13
vern350
like a rock
vern350's Avatar
I would think the cables would be the same.
Old 09-19-2008, 02:35 PM   #14
Pyrotechnic
Actually, the Turbo 400 doesn't have a kickdown cable at all. It uses an electronic switch on the gas pedal that senses WOT.
Old 09-20-2008, 01:50 AM   #15
spudz
spudz's Avatar
You know what....your right... I only had the truck a few days and when I read this I crawled under it and it does have a 350th.. The owner told me it had a 400...My mistake for not looking... THANKS again everybody...
