09-19-2008, 01:00 AM | #1 |
Before I order my 4 link, I have one question.
How come I have never seen a 5 link? That is; 2 parallel bars (one on each side of the frame rail) and a pan hard? I have never seen this installation so Im sure there has to be a reason.
Im kind-of-a novice fabricator and this would be easy for me. I dont feel comfortable with the install of the triangulated 4 link. And the parallel bars looks easier to install but I will have to fab the mounts to the rear end like jlaird did to get it parallel with the ground. Anyway, any comments on the 5 link? Thanks -Marc
Blazer Project |
09-19-2008, 02:39 AM | #2 | |
Re: Before I order my 4 link, I have one question.
09-19-2008, 08:16 AM | #3 |
O, I was under the assumption that a parallel 4 link was only limited to the type that has the two bars vertical (one on top of another) on he outside part of the frame. But that makes sense.
Blazer Project |
09-21-2008, 11:55 PM | #4 |
Yeah that's what a parallel 4 link is, and that's the part where it gets its name, but those have nothing to center the axle from moving side to side so that's where the panhard or watts link comes into play.
10-06-2008, 07:37 PM | #5 |
Stirrer of the Pot
I have a parallel 4link + panhard. did you order your kit yet Marc?
10-07-2008, 12:14 AM | #6 |
Dustin, no I didnt yet...
Blazer Project |
10-21-2008, 12:33 AM | #7 |
A 5-link is 2 forward loer bars an upper frt wishbone and 2 rearward facing "lift bars" on swinging pivots. super lift capabilities and travel. Does use up quite a bit of chassis space but nice when done right.
We build links to spec if needed. |
10-21-2008, 01:01 PM | #8 |
Stirrer of the Pot
that sounds like a 6 link.
10-21-2008, 01:46 PM | #9 |
You will need to sign up as a vendor before advertising product for sale.
10-21-2008, 02:25 PM | #10 |
Yes what he said a triangulated with rear lift bars is a 6-link. a wishbone with rear bars is a 5-link
10-21-2008, 03:17 PM | #11 |
Stirrer of the Pot
that would make sense.
10-21-2008, 03:27 PM | #12 |
Its Deja Vu time again
A lot of the Jeep guys run the Triangulated 4-link because they want max suspension travel up and down for crawling over things without worrying about the track bar binding.
Heck some even run it dual triangulated opposed to the outside bars being parallel. |
10-21-2008, 03:32 PM | #13 |
Junior Member
Not wanting to hijack the thread but does one ride or handle better than the other - triangulated 4 vs. parallel 4?
10-21-2008, 03:41 PM | #14 |
Who are you? Do you have a website?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
10-21-2008, 04:07 PM | #15 |
10-21-2008, 04:14 PM | #16 |
10-21-2008, 04:40 PM | #17 |
10-21-2008, 05:00 PM | #18 |
I think he just added that.
10-21-2008, 05:13 PM | #19 |
Yeah look up above it wasn't in his sig.
10-21-2008, 05:43 PM | #20 | |
Head Peon
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
10-21-2008, 06:28 PM | #21 | |
Junior Member
With the exception of our S-10 setups... that is the way most of our AirBars are. They are pretty common piece. |
10-21-2008, 07:50 PM | #22 |
- Clint - Last edited by Shane; 10-21-2008 at 11:08 PM. |
10-21-2008, 10:51 PM | #23 |
OK If any of them are done improperly, like anything else it will have less than desireable results. OK certain situations mandate a parallel 4-link, ie most newer trucks to keep gas tank in place, or at least a custom wishbone setup to retain tank. If panhard is long enough and properly mounted it will handle fine. Most consider them for racing use, but work great as long as panhard is longer for less deflection during travel. Triangulateds are a little less cumbersome if room allows. Again it depends on your goals, space, etc.
And yes my web page is in the sig, thanx for finding it. |
10-21-2008, 11:54 PM | #24 |
Stirrer of the Pot
Leave the pot stirring and pissing contests elsewhere. Thanks.
10-22-2008, 09:57 PM | #25 |
