09-19-2008, 04:30 PM | #1 |
motor mounts/engine perches for a 61
Anyone know where I can get the side perches/mounts for a 61? It currently has a 350 with the mount on the front(below harmonic balancer)and each side of the bellhousing. I've seen these side mounts for the 4-5-6 trucks but not the 61. I want to change the mount so I can install power steering. Thanks in advance for any advice.
09-19-2008, 04:51 PM | #2 |
100% gearhead
Re: motor mounts/engine perches for a 61
I am using the regular '63-'72 side mounts in my '62. You need to drill holes to make them work, but then you've got side mounts.
09-19-2008, 11:25 PM | #3 |
why do you have to change the mounts to install p/s. you are on a 3 point system and that is all yhat is required for proper eng mounting.
ron |
09-20-2008, 03:15 AM | #4 |
I may be wrong and someone please correct me if I am;but I think the power steering brackets have to bolt on where the front motor mount is bolted.
09-20-2008, 06:17 AM | #5 |
If you just need to mount power steering, why not consider the water pump mounted bracket from March Performance? Here's a link:
http://store.summitracing.com/partde...5&autoview=sku They make them for both short and long water pump set ups. Rick
RED RUMBLE 1963 C10 Chevy Truck Owned since 1984 |
09-20-2008, 02:45 PM | #6 |
If that is the stk sbc frt mount there should be a p/s bkt to fit. if that is also the stk mt there are a few people lloking for one.
you can put in the late perches but I think that you have to do a little notching in the frame to make them fit (nothing serious) as the later frames are a little wider. you can also buy after market perches which take the newer style of insulators, but you still need a little modifying. shouldn't be to much of a problem to put in (fab) a brkt to fit from something nwer ron |
09-20-2008, 04:55 PM | #7 |
Thanks for the info guys! I really like that summit bracket because it's a bolt on. Plan on keeping the truck standard shift anyway so I don't really need the side mounts. Thanks again. Bo
