09-23-2008, 09:22 PM | #1 |
Tilt Wheel Shift Indicator Light Bulb
Classic Bowties (Mel) wrote a very good procedure to change the shift indicator bulb in a tilt wheel. The procedure worked great but I cannot find in any manual (service or owner's) what the bulb number is. Many of the small bulbs are 194 but I would like to know if someone knows for sure. BTW I nearly broke my white plastic indicator off when I tried to take the PRNDL housing off. I used to wonder why most tilt wheel had the indicator broken off and now I know at least one of the culprits.
09-23-2008, 09:24 PM | #2 |
TILT COLUMN GURU
Re: Tilt Wheel Shift Indicator Light Bulb
That bulb is a 1445
09-23-2008, 10:11 PM | #3 |
The info I looked up on the 1495 claims it is a 28v bulb. I now suspect it is a 1445.
09-24-2008, 08:51 AM | #4 |
Restoration Virgin!
Hey Dantip,
can you post the link to the htread Classic Bowties did on this???...thanks!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
09-24-2008, 09:02 AM | #5 |
Here it is. The original question was related to a non-tilt fiber-optic line and morphed into info on changing the bulb in a tilt column. BTW this worked very well.
http://67-72chevytrucks.com/vboard/s...d.php?t=307100 |
09-24-2008, 10:18 AM | #6 |
The 1445 bulb works perfectly! I did however fail to make a mental note of the orientation of the slot in the metal bulb cover and had to use a mirror to figure it out during reassembly. This note should be added to the procedure. Thankfully this bulb is rated for 1000 hrs of use (should be good for the next 36 years or so). I could have changed 8 spark plugs in the time it took me to change 1 little light bulb.
09-24-2008, 12:13 PM | #7 | |
Restoration Virgin!
09-24-2008, 12:53 PM | #8 |
Moderator
I am going to have to check mine out...it does not work either. It did for a while, but hasn't in years now.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 11-27-2010 at 03:02 AM. |
11-26-2010, 09:24 PM | #9 |
i just changed mine, the bulb works, but it does not light up the indicator very well with that green piece on.
11-26-2010, 10:39 PM | #10 |
454 MAKES IT ROAR
Great info, now I need to find one of those little Green filter thingys, any ideas folks?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 11-26-2010 at 10:43 PM. |
