Old 02-17-2003, 12:03 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Proportioning Valve???
I have drum brakes all around and I also have a proportioning valve right after my m/c. I was wondering weather I need this or not? I dont think it came from the factory like this but I could be wrong. Please let me know. Also can I replace it with an adjustable proportioning valve? If so where can I get one and what kind should I get. THanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 02-17-2003, 12:13 PM   #2
vycc
vycc's Avatar
yes you need this.... it determines the amount of presure to give the front/back brakes......keep it on there
PS - if you have to replace it you can get them anywhere, they're for any chev.
1981 GMC Sierra 1/2 Ton SWB 4X4
vycc is offline   Reply With Quote
Old 02-17-2003, 12:42 PM   #3
XXL
Seņor Member
XXL's Avatar
This may simply be a distribution block with pressure sender (the connector for the brown wire on the bottom). That is what should have come on a drum/drum setup.
Kenneth
XXL is offline   Reply With Quote
Old 02-17-2003, 02:02 PM   #4
spinning wheels
spinning wheels's Avatar
If you replace it make sure its for a drum to drum setup. The disk to drum proportioning valves are different as are the disk to disk valves. The adjustable valves are usually used on race cars and are adjusted according to what track they are racing at. I don't think I would run one on a street vehicle. Thats just my opinion.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 02-17-2003, 05:35 PM   #5
Bruce68SB
That is not a proportioning valve. Although it resembles one. It is a "brake warning light switch. All drum brake trucks came with them. If you loose pressure in one side of your brake system, (either front or back) a piston inside it will move to one side (off center) and make an electrical connection for that wire you see hooked to it. That will light a dummy light on your dash. So kep it, you need it.
By the way, I would like to make a suggestion. Next time you ask a technical question like this, you might give some details about your truck, (year, series, engine, trans, ect.)
--Regards, BA
Bruce68SB is offline   Reply With Quote
Old 02-17-2003, 06:31 PM   #6
HotRod929
HotRod929's Avatar
Bruce68SB - Thanks for the info. all the details about my truck are at the bottom of all my posts.
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 02-17-2003, 06:32 PM   #7
wxman1
Bruce68SB is on the mark here.
Quote from 1969 Chevy Service Manual:
"Note: The brake pressure differential warning switch
is a non-adjustable, non-serviceable valve. If defective
it must be replaced."
"CA-KA-PA10-20, CA-PA-30,GA10-20 and SA-40-50 models
are equipped with a brake pipe distribution and switch assembly
(Fig 9). The front and rear hydraulic brake lines are routed from
the main cylinder, through the switch assembly, to the front and
rear brakes. The switch is wired electrically to the brake alarm
indicator light on the instrument panel. In the event of fluid loss
in either the front or rear brake system, the indicator on the
instrument panel will illuminate red when brake pedal is
depressed"
Image is attached.
So now having quoted the manual on this feature...I ask this
question. I have a custom dash. There is NO brake warning
light. So what good is this brake warning switch in MY case?
Jim M.
Mt Juliet, TN
wxman1 is offline   Reply With Quote
Old 02-17-2003, 08:12 PM   #8
spinning wheels
that is the proportioning valve. you still need regardless of the warning light.
Hey Hotrod, could you give a rundown on how you wired your Sun tach. I picked one up at a swapmeet. I'm stumped on some of the wires. This tach has six wires.
Old 02-26-2003, 12:28 AM   #9
Bruce68SB
:p Ok- You got me.
If you have drum brakes all the way around, and no warning light on your dash,. you can chuck the brake warning light switch.
Drum brake trucks do not need a proportioning valve.
This is because the extra braking power the front brakes need is accomplished
by another method. On drum brake trucks, the front wheel [brake] cylinder pistons are larger diameter than the ones on the rear brakes.
--Regards, Bruce
Old 02-26-2003, 02:11 AM   #10
HotRod929
HotRod929's Avatar
Bruce68SB - I do have a warning light on my dash. I think that the thing circled in the pic is just a brake pressure warning light swich.
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
