Old 09-21-2008, 12:56 PM   #1
thewrai6th
67-72 GMC vs Chevy cab, same cab?
I am looking for a new cab for my 69 GMC. I have found a decent cab near me, but it's a 71-72 chevy. Before I waste my time and money, like I did by buying Chevy fenders, I'll ask the question here.
Are the GMC and Chevy cabs the same in 67-72? Just talking about the shells, not any parts or accessories.
1969 Stepside restoration
thewrai6th is offline   Reply With Quote
Old 09-21-2008, 01:10 PM   #2
71swb4x4
71swb4x4's Avatar
Re: 67-72 GMC vs Chevy cab, same cab?
69-72 Chevy and GMC cabs are the same.
Here are differences between cabs that I can think of:
67-68 Chevy and GMC had the hand pull emergency brake, as well as the throttle rod. Of course some 67's had the small back window.
I believe the throttle cable started in 69, but it is possible that it didn't start until 71. Either way that is an easy mod, so I wouldn't use that as a reason not to buy.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-21-2008, 01:20 PM   #3
Blue_71
Bloo
Blue_71's Avatar
69 and 70 actually still used the rod, so technically the cabs go the same as grills, 67/68, 69/70, 71/72. 67-68 also had the fuse box turned a different direction. ive never tried the cable and rod conversion myself though
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 09-21-2008, 02:11 PM   #4
thewrai6th
My 69 is throttle rod. That's one thing to think about.
I have the large back window also, and foot brake. I'm not going to worry too much about the fuse box.
Sounds like I found a good match, now to go and check it for rust. Thanks for the info!
Old 09-21-2008, 03:04 PM   #5
71swb4x4
71swb4x4's Avatar
Here is the thread on how to convert (which won't matter if you buy the newer cab). If you buy the newer cab I would just use the throttle cable.
http://67-72chevytrucks.com/vboard/s...d.php?t=170383
Old 09-24-2008, 10:16 PM   #6
chevy29267truck
there the same the only thing diffent is the name and maybe some part #s
chevy29267truck is offline   Reply With Quote
Old 09-24-2008, 10:29 PM   #7
msgross
msgross's Avatar
no big difference unless you find a 67 small back window...some small differences in 67/68 firewall but it will still work I think. 4WD's and bigblocks had a removeable high hump cover as well and 2WD SBC and I-6 didn't.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-25-2008, 11:40 PM   #8
chevy29267truck
ok cool
i have a 1967 chevy 3/4 ton long wheel base truck
well i will be puting togeter a truck for my dad the cab from a chevy k/10 title off a 1971 chevy c/10 there will be parts from a 1971,gmc,truck 1967 chevy truck 1970 chevy truck and i think 1968 or 1969 chevy truck the engine small block chevy tranny 4,speed short wheel base truck fleet side bed
Old 09-26-2008, 08:36 AM   #9
Shyguy
Junior Member
Shyguy's Avatar
We put a '67 cab off a 3/4 ton frame on to a '69 short bed 1/2 ton frame using the 3/4 ton bushings, with out knowing that the 3/4 ton bushings were taller at the rear.
Now some time in the future we will have to put 1/2 ton rubber bushings on the back of the cab mounts so the fenders will properly line up to the cab.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 10-13-2008, 08:51 PM   #10
mark57
Wanted to buy parts are not permitted in this part of the forum nor from a nonsubscribed member.
Please go over the rules.
mark57 is offline   Reply With Quote
Old 10-13-2008, 08:56 PM   #11
teeitup
Just like to part out trucks!!
teeitup's Avatar
A couple other things are 71-72 cabs have the vent in the door pillar. 71 cabs have a riser in the metal for the rear view mirror
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 10-14-2008, 12:55 AM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
since the original question was GMC verses Chevy, they are the same, however, some GMC cabs had the clutch hole on the toe board instead of the firewall.
