Old 10-01-2008, 12:51 AM   #26
cstm68
cstm68's Avatar
Re: lowerd my truck !!! but...
Originally Posted by Lated View Post
I used 2 1/2" ds and a 1" drop spring and my tires rub if I hit much of a bump. How tall is your wheel/tire combo, and where did you buy the springs and spindles? I think my tires are 29" tall, and they are tucked up inside the fender. I don't think yours looks that much lower than mine. I think I ended up with alot more than the intended 3 1/2" drop. Here's a before and after with the same height tires. Looks like I got more like 5 or 6" to me. Did you expect your drop to put your truck as low as it is, or did it end up lower than you expected?
my tires are 28'' tall, they rubbed when i put 3 inch colis in so i swaped for 2 inch. now the front is 4 1/2" im not shure if it rubs much when i turn, i havent driven lowered yet. but i need to bolt up the inner fender to the outer better and that should give me about a 1/2'' then it will come up a little when i lower the rear the rest.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 10-01-2008, 12:54 AM   #27
LuckyHenriksen
LuckyHenriksen's Avatar
Man your truck looks badass. I havent seen it since you got it all painted and put together. Love the color and cowl hood. I had 2 1/2 in drop spindles and 3 inch drop springs on mine at first, but I only had like 2 inches of clearance from the header collectors, and was scraping everything. Went to a 1 in. drop spring and its a lot better, but no wicked stance.
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
