Old 10-02-2008, 02:27 PM   #1
SkylineNXS
SkylineNXS's Avatar
Coolant and Oil gone missing?
Hey guys, so after the fun no oil fiasco about 5 weeks ago, i changed the oil and everything, topped it off about three weeks ago and have been checkin it since. So this past weekend, at three weeks since change, i added 1 qt to bring it back to full. In those same three weeks, i had to refill the coolant reservoir since it was almost / completely empty. Would this be a head gasket problem or what? I dont know where else it could go. I put a new rad cap and stop leak in it, so i know its not leakin from the cap at least. Thanks....
By the way is a 87 350 TBI....
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 10-02-2008, 03:00 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Coolant and Oil gone missing?
does it appear to have water coming out the exhaust or white smoke? or do you have steady blue smoke ? how many miles on it?
have you crawled under it and looked for any leaks?
perhaps use a pressure tester on the coolant system and you could do a compression test to see if theres a head gasket problem too
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-02-2008, 03:54 PM   #3
Albatrossian
Georgia Boy
Albatrossian's Avatar
And check if theres water in the oil..
Albatrossian is offline   Reply With Quote
Old 10-02-2008, 05:01 PM   #4
SkylineNXS
SkylineNXS's Avatar
Im pretty sure no water in the oil, and i have noticed a little smoke out the exhaust, however, lately, its been pretty cold whenever i drive it, so its hard to notice, its definately not very blue. The pan and flywheel cover have a little oil "spray" on em, and the little drip that always develops at the very buttom, but its very minimal. I think ill try and do a compression and pressure test, gotta get eh stuff for it first though...
BRAD
Old 10-02-2008, 05:55 PM   #5
old Rusty C10
unless its really damp out the white smoke should disappear once the truck is at operating temperature...
Id crawl under the truck with a penlight and carefully inspect all of it sounds like a seal may be going relating to oil and ive had problems with the lower end of a water pump sorta weeping.. if at all possible get some gunk and clean the motor and then run it a week and see whats going on if it leaks... also im not familiar with your story about the oil fiasco but did you at any time have the cooling system open and not get it completely full? perhaps an air pocket which "burped" causing the overflow tank to go low?
also if you had water in the oil it would look like coffee with milk in it that sat for three or four days in the cup should be pretty easy to see .. you should also inspect the bottom of the oil cap too and make sure its now showing moisture
Bob
I hate cancer!!
Old 10-03-2008, 01:53 AM   #6
SkylineNXS
SkylineNXS's Avatar
Will do, thanks guys. Ive been wanting to clean up the engine compartment anyway, so ill do that this weekend. the fiasco is noted here....blast cant find it, it was a while ago. Bascially i bought the truck in june and checked all the levels and it was good, then went 3 thousand miles and left for college, and on the way down the engine got really hot and started kncokin really bad, stopped and had to add 4 qts of oil to get her back to full. I wouldnt doubt that that probably has something to do with my current problem....
BRAD
Old 10-03-2008, 03:54 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
I would say one of two things, Either a bad head gasket or a cracked head. There is a test that a good radiator shop can do to see if there is leakage into the coolant system from a cylinder. It will check for hydrocarbons or carbon-monoxide in your radiator.
Old 10-05-2008, 04:39 PM   #8
SkylineNXS
SkylineNXS's Avatar
Ok so i have yet to test anything, but today i was working on undercoating the wheelwells and there seems to be at least some sort of leak on the front either at the water pump or at the oil pan. It appears to come from above the oil pan, but ts hard to see up there....it "drips" down the pan and then onto the front of the main crossmember...would this be water pum or oil pan gasket or something else? Thanks....
by the way it appers to be somewhat green but mixed with all the gunk its really hard to tell exactly what the leak is..
BRAD
Old 10-05-2008, 04:48 PM   #9
SkylineNXS
SkylineNXS's Avatar
These are the best pics i could get...
Old 10-05-2008, 05:22 PM   #10
truckdude239
truckdude239's Avatar
thats either a front main seal leaking or the oil pan, as to the coolant i'm not sure i got cars i severice at work and fillt he coolant tank and 3000 miles later i am doing it again but we can;t find any leaks and pressure test is good
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-05-2008, 06:29 PM   #11
SkylineNXS
SkylineNXS's Avatar
The front main seal was what i was worried about....how in depth is that to get to, i have yet to do one. Basically all the way to the block or? Thinkin about doin the repair over my winter break, have a month to do it...
BRAD
Old 10-05-2008, 06:35 PM   #12
COMP
re-torque the pan and clean it up and drive it and look again
COMP is offline   Reply With Quote
Old 10-05-2008, 06:44 PM   #13
SkylineNXS
SkylineNXS's Avatar
will do...
Old 10-05-2008, 06:45 PM   #14
piecesparts
I would look a little higher and see if there isn't a coolant leak also. Get an inspection mirror and a flashlight and look close at the inside of the pulley on the water pump (water pump front seal) and also at the gaskets where th epump seats against the block.
A coolant leak will make a smaller oil seapage look really nasty and that could what you are really looking at in your pictures.
Get a spray can of brake clean and wash that area down and wipe it clean for a better evaluation.
Old 10-05-2008, 06:46 PM   #15
SkylineNXS
SkylineNXS's Avatar
sry, forgot, anyone got torques on those bolts? I dont have an assembly or service manual sadly...
BRAD
Old 10-05-2008, 07:20 PM   #16
84 400
Sb 400 club
84 400's Avatar
Brad that looks Identical to my water pump leak. Mine was leaking from the WP weep whole and the gasket on the impeller cover. I just got a new pump from napa. Clean the area and re inspect it.
Also does anyone have TQ specs for the oil pan?
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 10-05-2008, 07:39 PM   #17
old Rusty C10
i agree about the water pump thing.. id invest n a can of gunk like i mentioned earlier and clean things down good then see exactly what you have,, using a mirror and light as another guy suggested
Bob
I hate cancer!!
Old 10-06-2008, 01:29 AM   #18
SkylineNXS
SkylineNXS's Avatar
Alright, ill get on that tomorrow, im also thinkin like a lot of u guys its more water pump than anything. I got a little time tomorrow b4 class where i can do some lookin. Thanks...
BRAD
Old 10-06-2008, 06:40 PM   #19
truckdude239
front main is not thatr bad jus tremove pully and balancer an hour worth of work if eveything gos right
David fuller
2000 Tahoe 5.3l 378
