Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 09-28-2008, 07:27 PM   #51
Rokcrln
Rokcrln's Avatar
Re: LFD's 4dr Burb Build
Another 6hrs down and way to many more to go! I sectioned the outer door edge were the window felts go so it would match the pass side and not drag on the glass. I just cut sections out of a donor front door and Tig'd then in place. Then I made the cradle for the fixed vent window and installed the inner door handle latch mounting area. Then 3hrs of fun started when I had to rebuild the door lock system in reverse but it is done and works great.
Their Will not be any progress until next weekend because I am taking off in an hour to head down for my class this week with Lazzy to learn the English wheel, power bead roller and other panel fabrication tools. I will be taking pics
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 09-28-2008, 07:53 PM   #52
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Whoa, good work man! So many hours for what I though was a simple little thing.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-28-2008, 08:49 PM   #53
Rokcrln
Rokcrln's Avatar
Yep in theory it should be a simple to medium thing to do until you get into it. Then if you want to make it look like it rolled off the assembly line then it takes on a whole new time frame.
Kevin
LFD Inc.
Old 09-29-2008, 03:09 AM   #54
Frizzle Fry
Frizzle Fry's Avatar
I about to start playing with my spare doors Thanks for the info on the primer. What's the blue stuff?
Frizzle Fry is offline   Reply With Quote
Old 09-29-2008, 09:09 AM   #55
Rokcrln
Rokcrln's Avatar
It is just layout ink or machinest dye. If you need any detailed picks for the spare doors let me know, I have a few laying around
Kevin
LFD Inc.
Old 09-29-2008, 01:57 PM   #56
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Man Kevin, she is looking good.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 09-29-2008, 08:32 PM   #57
turbojunker
Kevin
LFD Inc.
This one seems to be going faster than the one you did on the pickup. Is it different or did you just learn from the first one?
turbojunker is offline   Reply With Quote
Old 09-29-2008, 09:39 PM   #58
Rokcrln
Rokcrln's Avatar
Both! Plus this is not damaged or rusted like the truck was. But I am also going to the extra step on this one and making it as stock as posible.
Kevin
LFD Inc.
Old 09-29-2008, 09:45 PM   #59
skchevota
skchevota's Avatar
The burb is looking good. I like the Cabrio at Dominator as well.
skchevota is offline   Reply With Quote
Old 10-01-2008, 09:11 AM   #60
gringoloco
A guy with a truck
gringoloco's Avatar
Watching...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 10-01-2008, 12:51 PM   #61
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Kevin
LFD Inc.
Dude, thats awesome
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-02-2008, 01:36 AM   #62
Rokcrln
Rokcrln's Avatar
So here is just a tease of what I made while in class. In most pic's you can see the flat plate I started out with, it was suck a blast! Now I need to sell Low-Buck so I can afford the tools I need to build more and more and more......
Kevin
LFD Inc.
Learning curve or a fender as Lazzy calls it.
Alum hood scoop.
Rear quarter panel.
A pillar.
This is the start of the door.
Old 10-02-2008, 02:22 AM   #63
Rokcrln
Rokcrln's Avatar
Well good news my electric life power windows showed up today. I ordered one set to check out because they do not make a set for the rear windows of the burbs only the front's. After a few minutes of looking and a few quick measurements I do believe they will work great in the rear doors with very little modifications. If I get a few projects done Thursday I will do the mod and see how well they work. Electric life is a direct bolt in for the fronts of the Burbs, truck and blazers and very soon my rear side doors
And yes I will show a step by step to mod these for anyone else wanting power windows in all 4 locations.
Kevin
LFD Inc.
Old 10-02-2008, 03:11 AM   #64
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
I Bet that was a Blast making those Part's, Just Think how much Time & Effort you will be saving with Your Creation's once you get the Equipment.............
Thank's for Sharing the Pics...........
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 10-02-2008, 03:41 PM   #65
Rokcrln
Rokcrln's Avatar
Yes it was a blast! Here is the end result of my first 3 days. I can't wait for the 5 day class
Kevin
LFD Inc.
Old 10-02-2008, 05:09 PM   #66
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Dayum, sounds to me like that class is well worth it, how much does it cost?
Old 10-02-2008, 05:14 PM   #67
paintpyro
paintpyro's Avatar
Nice work Kevin. I met Lazze a couple of years ago at the GNRS. I loved the fact that you didnt have to work the steel over a bag before you started wheeling, keeps the noise down, neighbors happy. He sure is proud of his $tuff.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 10-02-2008, 06:10 PM   #68
Rokcrln
Rokcrln's Avatar
$1350.00 for the 3 day class and $2350.00 I think for the second class and it is a 5 day.
Originally Posted by paintpyro View Post
Nice work Kevin. I met Lazze a couple of years ago at the GNRS. I loved the fact that you didnt have to work the steel over a bag before you started wheeling, keeps the noise down, neighbors happy. He sure is proud of his .
Yes keeping everyone happy is the key to good neighbors and your right he is very proud of his stuff but I have never used equipment that responds as fast as his does. His Bead roller is also very, very adjustable and that is key to good panels when all is said and done.
Kevin
LFD Inc.
Old 10-02-2008, 06:40 PM   #69
Brent5631
Brent5631's Avatar
Are you gonna finish that coupe or leave it as art?
1956 Chevy 3100 Big Window
Fuel Injected 6.0
Corvette Suspension
Four Link Rear
Brent5631 is offline   Reply With Quote
Old 10-02-2008, 09:50 PM   #70
Gorn
Gorn's Avatar
Ron Covell rules! I think I have every movie he has ever made. Course they are just the basics. Heck I even got the motorcycle ones and I am not into bikes.
It is better to live one day as a Lion then 100 years as a Sheep
Dingers Build Thread
Dingers Before Pic's
My 67 Camaro
Gorn is offline   Reply With Quote
Old 10-03-2008, 12:10 AM   #71
Rokcrln
Rokcrln's Avatar
This will stay as ART! I can always build another set for a full car after I have the rest of my set up. I can also use it as a template for the next one because I made sure every part is dead on so it could be finished down the road. But since now I have the basic skill to do it again I think it would just be way too cool to have this as ART.
I have allot of Ron's stuff as well. This body side was made in a class I had with www.Lazze.us , I had Ron's 2 day class a few weeks ago. I am a firm believer in you can never learn too much so I am always trying to find new info.
Burb new! I modded one window regulator today and I will do the other side on Friday for a How-To write up. I installed the one I did today and it worked great for one revolution until the glass came out of the old bottom Chanel, no fault of the regulator kit just old parts but it did work great that one time.
Kevin
LFD Inc.
Old 10-05-2008, 02:56 AM   #72
woodwright
Enjoying left field
woodwright's Avatar
Awesome fab work man. How do you have your tig set up to weld sheetmetal? (Electrode size, rod size, amperage) When you hammer and dollie afterward,are you stretching the weld spot back out? I cut down my long bed like you did with low buck, and had a hard time keeping things straight. I still have one corner that I nned to work on.
woodwright is offline   Reply With Quote
Old 10-05-2008, 07:53 AM   #73
Cyclone44
Step Brother
Cyclone44's Avatar
Man that is some awesome work you do....
Cyclone44 is offline   Reply With Quote
Old 10-05-2008, 12:23 PM   #74
Rokcrln
Rokcrln's Avatar
For the most part I try and match my rod size to the metal size. For sheet metal I use 1/16th (orange) rod with .023 or .035 filler wire. Yes I stretch the metal after welding because any time you weld it will shrink the weld area. So even if you get a "Pucker" out side your work area it is still from right at the weld location. Also keep in mind any low spot you have is surrounded by a high spot so it can get tricky figuring out what is needed.
Thanks I try and I am always learning and it is great I can show my progress here and other people and get ideas from it and I get allot of ideas from all of you as well.
Kevin
LFD Inc.
Old 10-06-2008, 07:10 PM   #75
Rokcrln
Rokcrln's Avatar
Well not much progress but I did get the door gap adjusted and then leaded in. Next wil be pulling the door back off and finish welding the inner panel and the front edge.
Kevin
LFD Inc.
